Old 12-26-2007, 03:03 PM
t/a 6.6 t/a 6.6 is offline
V6 question
Ok so i have a big question having to do with the exhust note, or sound, that a v6 engine produces.
why is it that a 3.8 liter v6 from ford as well as the Buick 3.8 liter sound so much more like a v8, (it has more of a low rumble) than say a 4.0 v6 form ford, or a dodge 3.2 litter v6?
does it have anything to do with the fact that the 3.8 liter v6's are 90 degree blocks, while the 4.0 is a 60 degree block?
Old 12-26-2007, 04:58 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: V6 question
the 3.8 is a pushrod engine, the modern 4.0 ford is SOHC. I'm not familiar with a dodge 3.2, but the dodge 3.5 is DOHC. That will greatly affect the sound. There's also bore and stroke differences. I believe a car that gets its displacement from long stroke will sound deeper than an engine that gets it by large bore.
There's also the matter of valve timing and mufflers. Some exhausts are just tuned to sound differently.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 12-26-2007, 06:27 PM
maxwedge maxwedge is offline
A990 racer
Re: V6 question
Different firing orders in the various engines also change the exhaust note.
Old 12-26-2007, 08:30 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: V6 question
IMO that's it. The 60 deg V6 pushrod engines I have built/owned sound different than my 3800 series Buick engines just as you describe here, even though they are mechanically very similar.
Old 12-27-2007, 05:03 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: V6 question
True, but the 90* V6s mentioned have offset cranks, meaning the firing order is evenly distributed just like a 60*.
Most of it is exhaust construction. Part of it is cam duration, compression, and other engine factors. Put a dynomax exhaust on all of them and they'll sound remarkably similar. Any difference at that point could be attributed to cam timing, difference in exhaust length/curves, exhaust ports/manifold configuration, etc.
Dragging people kicking and screaming into the enlightenment.
Old 12-27-2007, 10:39 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Re: V6 question
Exhaust note can be affected by a number of things:
Displacement
Firing order
Intake & manifold
Exhaust & manifold
Head design
Valve timing & lift
OHC vs OHV
I'm sure I'm forgetting something. My point is that there are a lot of variables that affect exhaust note. Here is a good example. My GTC has a 2.2L I4 SOHC. It has an intercooled Garrett T3 with an exhaust that goes from 2.5" to 1.25" and has a cat right after the downpipe and the muffler at the tail end of the car. Stock it had a low burble thanks to the turbo but it was VERY subdued. I have changed the exhaust to a full 3" mandrel bent system with the muffler right after the cat. People that here it don't think it's a four cylinder. Also, I'm sure it will change when I put the 3" downpipe, swing valve, header, intake, head work, and the new turbo and intercooler. All those things will change the note. Here is how it sounds right now:
http://www.synapsepc.com/Hosting/Ima...04/exhaust.mp3
Had I put the muffler at the back instead of right after the cat it would have sounded different.
Actually, in the mid 90's the 3.5L was a SOHC with 24 valves per cylinder. Later they changed it to DOHC.
Old 12-28-2007, 01:11 AM
curtis73's Avatar
Re: V6 question
What always fascinated me was why a V8 with dual exhaust doesn't sound like two 4 cylinders idling side by side. Just goes to show how there are tons of variables.
Old 12-28-2007, 02:38 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: V6 question
Originally Posted by Polygon
Thats a might fine sounding tractor you got there son.
Old 12-30-2007, 02:35 AM
Polygon's Avatar
The Red Baron
Re: V6 question
LOL, you're the first person that didn't like it.
Old 12-30-2007, 06:34 PM
Steel's Avatar
Steel Steel is offline
Re: V6 question
Unless its a flat-crank V8, like lotus, ferarri and such.
Old 12-30-2007, 11:32 PM
Moppie's Avatar
Master Connector
Re: V6 question
Hey, didn't say I didn't like it
The Lotus V8 has to have one of the oddest exhaust notes.
The idle sounds like two out of tune 4 cylinders, each with a mis fire on a different cylinder.
Old 12-31-2007, 04:46 PM
Steel's Avatar
Re: V6 question
<3 flat crank v8's. Probably the only engine i'd consider swapping into a 7.
Old 01-03-2008, 05:10 PM
Polygon's Avatar
The Red Baron
Re: V6 question
LOL, nice!
