Old 02-17-2003, 02:20 AM
eklipz eklipz is offline
Things to look out for when buying a 4G?
If I were to look at a Civic hatchback, what should I take note of? Are there any problems with the 4th gen's that are really hard to fix and if so what I should be looking out for? I have my car up for sale and i'll be looking around for some 4th gen's and I'd like to know some common problems and what to look out for before hand. Thanks.
http://mindsys.serveftp.org
Old 02-17-2003, 02:25 AM
׿Pyro¿× ׿Pyro¿× is offline
Send a message via ICQ to ׿Pyro¿× Send a message via AIM to ׿Pyro¿×
I'd look out for the usual rust spots and dings. And it doesn't hurt to ask to look at the engine and drive it around the block a few times. Just be sure to look out for anything leaks oil or anything like that
Jameson
Old 02-17-2003, 03:03 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
rust. find one with NO rust.
Old 02-17-2003, 03:09 AM
tbk49's Avatar
tbk49 tbk49 is offline
Send a message via MSN to tbk49
look at the rear fender, right between the bumper and main body, usually theres rust there...also check for clutch (how far down to engage), axles (knocking noise when turning), any grinds in the tranny, check vin for clean title, physically look at the cars interior exterior...any leaks? or running fluids on brake lines? pull each spark plug and see if the rpms drop...um yea other than that look for any signs of rust, usally on the rear and front fenders
blah
Old 02-17-2003, 09:10 AM
civic4g civic4g is offline
Send a message via ICQ to civic4g Send a message via AIM to civic4g Send a message via Yahoo to civic4g
Check to make sure the A/C works well.
Most people will turn the heat on in the winter, but since it's cold already, forget to check the A/C.
If you come across an SI make sure the sunroof doesn't leak (sometimes its an easy fix, sometimes its not).
And everyone elses ideas I agree with
There's one here in Atlanta someone is selling for $625 with a broken head. LOL
Old 02-17-2003, 09:13 AM
Civic Rush's Avatar
Civic Rush Civic Rush is offline
Send a message via AIM to Civic Rush
a HB in ATL. What Model.
Old 02-17-2003, 09:20 AM
1990civic's Avatar
1990civic 1990civic is offline
check the rear strut towers, some times they will rust through, then you have a real big problem!! the whole rear end will just drop to the ground.
Upgrades:
Si Interior
Painted Interior
TACH
WW Body Kit
Clear Tail's (no altezza's here)
http://www.automotiveforums.com/img.php?129408DSC00972.JPG
****hopefully not the end****
Old 02-17-2003, 10:48 AM
Stali08's Avatar
Stali08 Stali08 is offline
Send a message via AIM to Stali08 Send a message via Yahoo to Stali08
make sure that the key goes in and out easily, because with older cars u have to think of how many times a key has gone in and out of the ignition. Mine is a pain in the ass to get out, but good luck.
PeacE
Things to look for when buying a 3rd generation El Camino? philipk65 El Camino 0 07-13-2007 03:37 PM
problems to watch out for when buying a e30? dvs909 M3 5 08-19-2006 03:37 AM
Things to look for when buying an Integra. skorpionbite Integra 2 08-07-2004 08:24 PM
What to watch out for when buying a civic coupe blitz_syd '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 10 08-07-2003 12:50 PM
what things to look for when buying a used car? DJ Cripsen Integra 1 12-22-2001 06:49 PM
