Go Back   Automotive Forums Car Chat > Honda > Integra
Old 12-21-2001, 09:44 PM
DJ Cripsen DJ Cripsen is offline
Send a message via AIM to DJ Cripsen
what things to look for when buying a used car?
Hi, Im planning on buying a used 94-96 acura integra ls or GSR depending on price. I found a car lot which sells many acuras in New Hampshire from $7000 to $9500. Now, Im wondering what should I look for to check and make sure the car will last when buying a used car? Any tests I can run. Who should I take it to?
Thanks alot:smoker2:
I am not a newbie, just changed my name.....member since december2000
Old 12-22-2001, 06:49 PM
engsr's Avatar
engsr engsr is offline
i would probably take the car to a dealer to inspect, unless of course, you know a mechanic that won't screw you around. otherwise, check for leaks, the contact point of the clutch (gs-r's are a higher clutch - at least mine is, so be careful there), tires, brakes, and the sound of the engine. the other thing you should look into is the vehicle's history - number of owners, number of collisions of any, the title (salvage, theft recovery), and whatever else. if you can get service records, that's a good indication of what has been done to the car if there were any problems. hope this helps. good luck.
Bryan.
Pure Honda member since August 2001
AF Nordic Crew #002
What should we look for when buying used F-150? amanda_easternon F Series 0 06-02-2006 06:29 PM
What to look for when buying a used Caravan? spielightdude Caravan | Voyager 6 05-10-2006 03:51 AM
What to look 4 when buying used rims Jimmy79 Tires and Wheels 4 02-06-2006 06:01 PM
What to look for when buy?? 93 240SX PossibleOwner 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 5 12-03-2004 06:12 PM
