Old 02-11-2003, 05:29 PM
R7Q R7Q is offline
Electrical Question
this is on a 92 Geo Metro Conv.....when I run the lights ...in about 10 minutes the car will die...and the battery will be dead...The 1st thing i replaced was the Alternator...which had no change!!!!! I can take the positive battery cable loose and the car will stay running so whats my problem???????.........thanks.......R7Q
Old 02-11-2003, 05:58 PM
bowtiebandit's Avatar
bowtiebandit bowtiebandit is offline
Send a message via AIM to bowtiebandit
does it stay running with battery disconnected and the headlights on?
Shop Foreman
Corvette Specialist
A.S.E. Master Technician
L1 Certified
A.S.E. Master Machinist
GM Certified Technician
Old 02-11-2003, 07:21 PM
R7Q R7Q is offline
Lights ON
with the car running....battery pos...cable off and the lights on....the car remains running with not much reported drain on rpm....???????????
Old 02-11-2003, 07:48 PM
I'd have to venture a guess that the battery may be to discharged and the alternator's output is being overrun by the condition of tryin to charge the battery and run the lights. I'd also take a good look at battery ground on the trans, they come loose alot and the wiring harness from the alternator. They rub through on the alternator bracket and the intake manifold bolts.
Shop Foreman
Corvette Specialist
L1 Certified
Old 10-07-2004, 04:09 AM
lawbob81 lawbob81 is offline
Re: Electrical Question
Bad alternator HOT terminal connection. Replace terminal with heavy guage round terminal and tighten down nut hard, clean terminal, that'll clear up problem. Your output HOT terminal is getting high temp due to poor connection at alternator. After running awhile, stop car, put finger on alternator hot terminal to verify if getting hot, if so, you know what to do.
air bag and electrical questions. 93 CV. frootlooprules Crown Victoria 2 03-19-2009 06:36 PM
535i electrical question khadijahatribble 5 Series 3 10-25-2003 05:44 PM
Need help with some electrical questions. dj_alto Engineering/ Technical 9 09-19-2002 08:44 AM
Electrical question.... SilverY2KCivic Engineering/ Technical 4 03-21-2002 08:42 PM
Electrical question... wiring lights to a switch! OisinT Engineering/ Technical 5 12-27-2001 02:37 PM
