Old 02-11-2003, 11:20 AM
rendog24's Avatar
rendog24 rendog24 is offline
question about running 2 ohms?
alright i got a 12 w6v2 and a viper 600d amp. i was looking at the diagram for the v2
http://www.jlaudio.com/subwoofers/pdfs/W6v2_DS.pdf
and i was looking at diagram b. does that 2 with that one symbol mean ohms?
cuz mine is connected from vc1- to vc2+. this means that i am running 8 ohms from this sub as it shows in diagram a, right?
"Don't touch what you can't grab, End up with two backhands, Put anthrax on a tampax, and slap you 'til you can't stand" - Eminem
Old 02-11-2003, 06:57 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
yes, that will make it 8 ohms
that funny little thing is the greek letter omega ..... used in electronics to denote ohms (resistance or impedance).
Old 02-11-2003, 11:26 PM
rendog24's Avatar
if i connected it the way it shows in diagram b with 2 ohms, it will make my sub hit harder, right?
Old 02-12-2003, 12:36 AM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
it should, wiring it to be 2 ohms will draw more power from your amp to your subs
Empty Pockets Racing Member #1
Old 02-12-2003, 04:02 PM
Audio Guy
only if your amp cqan handle a load that low
Old 02-12-2003, 06:13 PM
60hz163.5db's Avatar
60hz163.5db 60hz163.5db is offline
We sell Viper amps at my shop and i wouldn't recommend running it at 2 ohms it will work but not for very long.
"Working in car audio has it's advantages, but it also shows you how much money ppl have to waste."
Old 02-13-2003, 12:17 PM
turbcivic's Avatar
turbcivic turbcivic is offline
WTF?
A member of my audio team run a viper 600 at 1 ohm and it is stable. He also hits a 143 with it. All viper amps are at least two ohm stable and the 2500 won't drop below a 1.5 ohm load. I know becuase this is what i run. 1 Viper d2500.1 at 4 ohms and two viper 12.2s with the vcs wired down to 2 ohm and then connected in seris. All this good for a 149.2 in a 91 HB. Exactly what shop do you work at?
2007 dodge ram hemi sport-the tow/dd
1993 Civic HB-h22 with type s pistons, 125 shot, and some other goodies
1989 CRX(in the works)-h2b plus maybe some spray, or some boost
Old 02-13-2003, 12:26 PM
rendog24's Avatar
i read the manual for my amp and it said that running the amp into a speaker at 2 ohms would give it 400 watts rms. thats what the w6v2 handles at rms. it also says that running the amp into a speaker at 4 ohms would give it 275 watts. i am not even running that so i gotta be running only about 150 or so watts to the sub right now if i am running it into 8 ohms. well thanks for all the help you guys. i am going to just rewire the sub into 2 ohms and see how much harder it will hit. thanks.
Question about daytime running lights. JCL82 Silverado 3 03-28-2010 09:39 PM
Question About Day Time Running Lights On 03 Extreme S10 LITTLEBLACKEXTREME S-10 1 06-26-2005 01:02 PM
Quick KA question about running temp Mayday0017 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 2 08-24-2004 10:11 AM
Funny question about running out of gas RedRacerCivic '88 - '91 Civic | CRX | Wagon | Shuttlee 30 03-16-2003 08:18 PM
question about vtec in the long run vtecntrldSI '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 02-04-2002 12:44 PM
