Old 02-10-2003, 09:24 PM
joecwlaw's Avatar
joecwlaw joecwlaw is offline
WHY STICKY AFTER SPRAYED TS50
guys, this is my first time using the TS50. I sprayed on the Subaru WRC chassis without any primer. First I sprayed a very light coat, then I sprayed 2nd and 3rd time a small bit heavier. It covers very well. But after 1 day of drying, the surface is still very sticky......
I have similar problem with Tamiya TS13 as well before......I dont understand, what is the problem? is that coz' I did not shake it well? or other issue?
Old 02-10-2003, 09:29 PM
Jay! Jay! is offline
Horizontally Opposed
What are your weather conditions? Where did you let it dry?
Hierarchy of Subaru:
(Click to see mine!)
Old 02-10-2003, 09:33 PM
Vyacheslav's Avatar
Vyacheslav Vyacheslav is offline
Send a message via ICQ to Vyacheslav Send a message via AIM to Vyacheslav
Any paint is about to be sticky after 1 day of drying. Give it atleast 3 dasy
Old 02-10-2003, 09:35 PM
joecwlaw's Avatar
I put it in a plastic box with cover, and put a toothpick to absorb the moisture...
Old 02-10-2003, 09:39 PM
Vyacheslav's Avatar
the box should have ventilation, so the air can get inside of it.
Old 02-10-2003, 09:41 PM
Mainomega Mainomega is offline
I left a model to dry for about 20 hours, touched it with my finger and felt smooth and dry, so i put it in a plastic bag. 3 days later i take it out only to find the top of the model had a small imperfection.
I though the model was dry but it wasn't the part where the car and the plastic meet had joined togehter and messed up my paint. From now on i spray it and i cover it usually with the same box the kit came in for 4 days. and then spray clear on it.
Got Something Good ? E-mail me
Old 02-10-2003, 09:57 PM
.porkchop.'s Avatar
.porkchop. .porkchop. is offline
Send a message via ICQ to .porkchop.
i find that paints air better in open environments....
i usually let me models dry in open areas..tamiya paints usually dry to touch in less than 2 hrs
Old 02-11-2003, 12:00 AM
Asmenoth's Avatar
Asmenoth Asmenoth is offline
AF Premium User
I usually set my bodies on a self, under a clear box. I use Tamiya paints and have never had this problem. It's usually dry, and not sticky, after a day or two, but I usually do mess with it for about a week.
Do you know how fast you were going son?
No Officer, the speedometer only goes up to 85.
Old 02-11-2003, 12:38 AM
djmr2's Avatar
djmr2 djmr2 is offline
wrong
lacquers i use a dry to touch within 1hr but not full cured
tamiya lacquers are pretty much dry to touch after a few hours
not all paints are the same
joe, u probably want to keep the paint ventiallated as the gas will still coming out of the paint.
Old 02-11-2003, 12:44 AM
joecwlaw's Avatar
Originally posted by djmr2
wrong
thanks guys for your info. I think I will leave the cover a bit open and see.
BTW, I am wondering if I spray TS50 on the body, should I put clear before I put decals......if it is that sticky, once I place the decals on the ts50, I will not be able to fine-move the sticker to proper position.
Old 02-11-2003, 01:04 AM
djmr2's Avatar
joe
it's necessary to get the smoothest surface u can before u put the decals on, they'll stick better
so if u need to sand/polish the blue coat first, then put clear and then decals, then it's ok
make sure u put a clear over the decals after and polish it nicely..
TS-50 needs clear badly
Old 02-11-2003, 01:07 AM
joecwlaw's Avatar
thanks djmr2. I will start painting other parts tonight. Hope it all goes well.
Old 02-11-2003, 05:19 AM
flyonthewall's Avatar
Car Mod guy
I had the same problem when i used this spray. I always leave mine to dry for at least 1 week too, next to the hot water tank in the airing cupboard. It was still tacky many weeks later, after carefully adding the decals and trying my hardest not to leave fingerprints in the paint, the only solution was to give t a clear coat.
Old 02-11-2003, 07:36 AM
935k3's Avatar
935k3 935k3 is offline
I have had this problem with TS Sprays to. I airbrushed TS-49 on my Toyota GT-One and weeks later it still felt tacky and did not go a way until I put Future over it and the decals. I have never had the problem with the clear.
Old 02-11-2003, 08:24 AM
joecwlaw's Avatar
sorry but what is Future?
2001 infiniti i30t coolant is spraying Fpcwrestler Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 12-10-2010 12:51 AM
Why don't we have a bike pic sticky? CBURKE Street Bikes 5 03-19-2005 01:37 PM
