Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 12-09-2010, 06:16 PM
Fpcwrestler Fpcwrestler is offline
Red face 2001 infiniti i30t coolant is spraying
Hi my coolant is spraying on both the driver and passenger side. not to sure where its coming from as everything is green from the coolant. I will clean everything up this weekend and try to pin point the leaks. But my question is what can be causing this and if it can be fixed on my end or is this something I should be leaving to the professionals. I was very low on coolant yesterday so the engine ran a little hot I did get more coolant and not it is running normal. What can cause this and can this be fixed fairly simply?:
Old 12-09-2010, 06:19 PM
danielsatur danielsatur is offline
Re: 2001 infiniti i30t coolant is spraying
Was the coolant spraying on the inside, or outside?
Old 12-10-2010, 12:51 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Cabin = wouldnt notice if outside.
My guess is leaking cabin heater core. Swapping it means dismantling the whole dashboard: youll become a pro after doing that. However, not knowing the history, it can also be leaking hose (normally cannot). Check out.
Main issue is NO DRIVING before the engine coolant is leak free and gets normally pressurized. This means separate procedural bleeding from ALL air bubbles; most repair shops havent got a glue here. If it is not properly done, future is 'pain full'. FILLUP AFTER LEAK IS NEVER NOT ENOUGH. Air bubbles and/or low coolant means SURELY blown head gaskets - possibly blown engine... (in happy cases (?) this 'may be postponed' some 20k miles - but will happen)
3gen maxima has the computers sitting under the cell, will be fried.
See my CDomain coolant pages to get the idea, clic below.
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
2001 Chevy Cavalier Coolant System Problem getwilde Cavalier Problem Diagnosis 0 09-18-2009 06:43 PM
2001 Infiniti I30t (Strange sound) pls help hondac Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 4 04-27-2005 08:34 PM
DOES 98 Infiniti I30t Have any sort of body kits? EUROINFINITI Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 7 10-08-2003 09:54 AM
OEM 97 Infiniti I30t Center Caps jparraz Tires and Wheels 1 08-11-2003 05:02 PM
Infiniti I30t 96 remote programming brhodes Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 11-26-2002 08:24 AM
Tags
coolant , infiniti , spraying
