Old 02-10-2003, 09:06 PM
turfup turfup is offline
91 civic
I recently have had a new head put on my civic and it has never been right since. It smokes like crazy (blue and grey. I have been dealing with some shad tree mechanics and they can't seem to figure it out. It has 150 compression and it was a rebuilt head. Does anyone have any ideas of what could be my problem. I realize that it could be many things but I just wanted to get some opinions from others. I think that the rings might be bad. Also i have heard that if the rings are bad the pistons are as well. Is this true?:bandit:
Old 02-10-2003, 09:14 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Head gasket? It could also be the rings but I dont know about the pistons. Do the head and the block match up perfect? Is either warped?
Old 02-10-2003, 09:16 PM
91zc 91zc is offline
Are you losing oil and coolant? It might be the head gasket. If the rings are bad then you will need to bore the sleeves out to make a good surface for the rings to seal against. Removing extra materiual means you will need a larger bore piston and therefore the old pistons are useless.
91 civic 4dr
b16a
14.8@94
Old 02-10-2003, 10:15 PM
i am not losing coolant but oil is being burned. It looks like my car is on fire it smokes so much. I really don't know shit about cars, but I am learning very quickly. I am kinda afraid I am getting ripped buy this mechanic. My car has been in and out of his shop for three months and has never ran right since. How much is a head gasket and what is the head gaskets function? The head was rebuilt and was machined, I assume that means seals and possibly the head gaket but I am not sure. Are there any other possibilities? Thanks
:smoker2:
Old 02-10-2003, 10:59 PM
Redrum240sx Redrum240sx is offline
Send a message via AIM to Redrum240sx
if it smokes right after u start it up it could be the valve seals
93 Del Sol S
Eibach Sportlines
Tokico HP's
EBAY Strut/Stabilizer Bars
EBAY Short Shifter
Baer Track Kit
Old 02-11-2003, 10:03 AM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
Exactly...which should have been replaced when the head was rebuilt...Also, when the head was off, they should have been able to determine the condition of the rings/pistons. The head is easy work compared to the block, so any real mechanic would jump at the opportunity to do block work once they remove the head and see bad rings, etc..
Did the car smoke before the work??
The head gasket is the seal between the head and the block...usually if it is bad/not sealing, you get coolant and oil mixing in each other's compartments..
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 02-11-2003, 11:10 AM
91civicDXdude's Avatar
my d15b2 did the exact same thing. It smoked like the car was on fire so we put a new head on it. Didnt help. Come to find out, it was the oil rings. they are the thinnest and will usually be the first to burn.
My compression was 180 across all cylinders and still smoked :/
you might as well get another engine
Old 02-11-2003, 02:23 PM
turbcivic's Avatar
turbcivic turbcivic is offline
exahust guides are probly bad or they didn't check to see of the head was cracked
2007 dodge ram hemi sport-the tow/dd
1993 Civic HB-h22 with type s pistons, 125 shot, and some other goodies
1989 CRX(in the works)-h2b plus maybe some spray, or some boost
Old 02-11-2003, 08:44 PM
as for the exhaust smoke bluish smoke is oil and whitish smoke is coolant
93 Del Sol S
Eibach Sportlines
Tokico HP's
EBAY Short Shifter
Baer Track Kit
Old 02-12-2003, 03:44 PM
91 civic
It is not the valve seals and it is not the head gasket both have been replaced. I can't figure this out. Does anyone know a resonable mechanic in Maryland that could take a look at my car. Or better yet does anybody know where I can get a engine that has any type of warranty. I am sick of getting ripped off and I need my car back on the road fast.:smoker2:
Old 02-12-2003, 08:19 PM
if the head gasket was replaced and its still happening the head or block could be warped and have to be milled
93 Del Sol S
Eibach Sportlines
Tokico HP's
EBAY Short Shifter
Baer Track Kit
h23 swap 4th gen civic? 92lude91dx '88 - '91 Civic | CRX | Wagon | Shuttlee 4 03-16-2009 11:43 AM
civics civics civics.... sihondasracer Street Racing 10 07-28-2003 12:52 PM
Greddy 92-95 Civic Turbo question for 97 Civic Zor Forced Induction 2 01-22-2002 01:16 AM
99 civic OEM front lip on 98 civic? aprather24 Exterior | bodykits | Lighting 4 01-12-2002 01:04 AM
EK CIvic DX transmission on civic EX of same year - worthwhile? VTEC_boi Engineering/ Technical 5 12-09-2001 12:48 PM
