Old 02-08-2003, 10:15 PM
soulkeeper soulkeeper is offline
zc question
what all would I need for a DOHC ZC swap on an 89 civic DX
i am teh best i am teh best is offline
Banned
Old 02-08-2003, 10:17 PM
Old 02-08-2003, 10:24 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
Originally posted by i am teh best
1/1
yet again another pointless post by the n00b
i dunno ne thing about zc swaps but theres a few ppl on here who do, wait a lil while and u'll have lotsa answers
Old 02-08-2003, 10:26 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
1/1
Look man, I think just about everyone here has had enough of your shit, either contribute something constructive (aside from postwhoring) or go somewhere else where your whoring will be better tolerated.
Back to the situation at hand, Info on the ZC Check out this page http://dmoore.com/crx/zc.htm
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 02-08-2003, 10:43 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
or just do a search and you will a lot of info.
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 02-08-2003, 10:51 PM
i have been reading a lot, but I was just notified that the DOHC would need mounts and a b series tranny, is this true?
Old 02-08-2003, 10:57 PM
Banned
you newbs dont know what 1/1 means ?
Old 02-08-2003, 11:02 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
i am the best...i agree with melt, for awhile I was able to tolerate you, but going around calling everyone noobs when this is probably your first day here and you already have 30+ post, half probably from insulting people and calling people noobs. Look I really don't have a problem with you, but cool it down with your post whoring calling people noobs and being a smart ass.
EDIT: sorry to get O/T, but I really don't know that much about the ZC swap, but im sure you can find plenty of people who do.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 02-08-2003, 11:04 PM
Banned
ok fair enough, good attitude theodditie (seriously)
for the record to all the board newbs out there... 1/1 means first view first reply
I just need to find some one that has done a ZC swap on a 88-91 civic dx, than he can answer all my questions.
Old 02-08-2003, 11:39 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
This to my knowledge is definitly not true. You are able to use your existing motor mounts (I recomend getting new inserts for $20) and for the tranny, you can also use the one you already have. If you have a DX then you should upgrade to an Si tranny. It will also bolt right up. Overall, the ZC swap is very easy. Hope this helps.
Old 02-09-2003, 12:45 AM
walt0023 walt0023 is offline
Send a message via AIM to walt0023 Send a message via Yahoo to walt0023
ok a zc motorwill bolt up right to your car but it would def. be a good idea to switch over to mpfi. and it would be smart to upgrade to a zc or integra ecu. and thats about it. it will bolt up to your dx tranny but si tranny is the way to go.
Old 02-09-2003, 01:13 AM
seth 90DX/ZC seth 90DX/ZC is offline
Banned
OH boy, here we go again.. You better read all this dude!
For starters the diff between 88-89 and 90-91's are plentifull yet few... MPFI is on all the 90-91 (I believe) and DPFI is in the 88-89's... In order to use the ZC with the ZC intake manifold you will have to switch over to MPFI wich in itself is a whole new ball park... (I myself am not sure what all is involved... I just grabed all the stuff off a 90 SI for my D16A6 and moded the harness) The DOHC ZC engine will bold directly into your chassis without using aftermarket mounts, it is however smart to get new stock engine mounts before swaping because the ones in there have been beat on since 1989... The transition will work with a 90-91 SI (D16A6) trany... Use the the SI clutch and flywheel... You will probably want to get a new radiator before swaping the motor but thats just a sugestion and is not neccesary. When you get the engine its always smart to do the internal upgrades while the motor is out. You can get an engine manual for it from haynes its the UK edition in english (Thank me for that later, I looked for days before I found it!) You can use the SI ECU and that will work the best Ive looked at the dyno sheets! People say the ZC ecu is best and the 89 teg (D16A1) is second best because of the fuel maps, the SI ecu runs a little bit leaner and as we all know as far as N/A goes leaner is meaner! I saw 6HP increase when my homie tried the SI ecu instead of the teg one, i dunno about the ZC ones. You will need to modify some headers OR buy the DC top part for the 89 teg D16A1 and the bottom half for the 90-91 SI and you will still need to do some modification to your exaust system.
The best place to but is www.Hmotorsonline.com thats were I got mine.
Also I got a few ZC threads started in this forum, there is plenty of information there. your welcome.
Old 02-09-2003, 08:53 AM
thats where I'm geting the motor.
also, why would I need to swap out to MPFI when the engine comes with the intake manifold? would I still need to do the swap?
also where do you think I could find a decent Si tranny?
I am for sure going to go with the ZC ECU, ive heard really good things about this ecu and wanna give it a try.
so here is what is on my list to buy, please tell me if I need anything esle or forgot somthing
Si tranny
ZC Ecu
Inserts
exhuast system
is that all?
Questions,Questions,Questions.... r_c_inicial Mustang Talk 11 08-23-2005 08:26 PM
Questions Questions and more Questions H22silverbullet Prelude 15 07-30-2005 07:23 PM
Question Question Question Integra14 Car Modeling 2 12-07-2002 08:31 AM
