Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 02-08-2003, 06:22 AM
mad max 98 mad max 98 is offline
Arrow turbo size and peak hp
hey guys on the max where on the rpm band doeshp peak with turbos like t66 or t3t4 also any dyno graphs:alien:
Old 02-08-2003, 08:54 AM
Pick Pick is offline
2. many types of turbo available for my set up all depends on $$$ you want to spend. I can upgrade my turbo to T-66 if I want to. Just need to pay for a turbo and change two flanges. Or T3/T4 for fast spool for street racing
3. You can run different levels of boost easily without changing any pullies. Just a boost controller (or even a vacuum tee) can change the boost level. I can alter boost wthin 10 seconds with boost controller. I can switch between two predefined boost levels within 2 seconds.
4. 9 psi boost at 4200 rpm 4 psi boost at 3500 rpm. S/C doesn't make full boost until red line typically ... for centrifugal type that is (Vortech is centrifugal
Here is a quote I got from a guy off the dot org.
Here is his stats:
Turbocharged 1997 5 speed SE
429.7 HP and only 395.9 lb-ft @ 12.5 psi
Sounds good to me.......
Old 02-08-2003, 09:43 AM
pick, first thanx for the reply, but my ? was wher on the rpm does each turbo peak its power , for example a big turbo will peak at 5500 rpm a medium will peak at 4000 rpm so it doesn't matter what level of boast u r running it will still peak almost at the same point so i'm trying to find out the peak points for each one on the maxima, i hope u got me
Old 02-08-2003, 11:19 AM
I'll keep looking. I'll try to holler back at ya.
Old 02-08-2003, 11:39 AM
Here is his dyno, if it helps. He is running a T4 turbo.
Old 02-08-2003, 11:50 AM
oh thanx man , do u have any for t3t4 or t66
Old 02-08-2003, 02:04 PM
I'll try to find them.....
Old 02-08-2003, 02:38 PM
Alright, what I have found is that:
1) The T3T4 turbo's torque dies off at about 5 grand, just like stock.
2) The T04 has a pretty good amount of lag at high power band, according to some, but many disagree with that, because it is a big turbo.
3) The T3T4 turbo has good torque at about 3 grand.
4) the t66 has pretty good all-arond power, but is big, which, again, means more lag. It is used in a lot of big turbo Supra's. I'd say power is around 4 grand. A t66 can handle 8,000 rpm's.
Old 02-08-2003, 02:40 PM
The t66 may even peak around almost 6,000 rpm's, or somewhere a little bit lower than that.
Old 02-09-2003, 10:21 AM
where did u get this info from bud
Old 02-09-2003, 11:30 AM
Maxima.org. Those guys know what they are talking about.
Turbo help, like which size and if it'll work CalicoDreams Forced Induction 7 08-30-2005 12:41 PM
turbo choice and size for 300hp? daryldoo 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 6 07-28-2003 11:30 PM
Turbo sizes xlosinghopex Forced Induction 3 04-07-2003 11:15 PM
lancer turbo size, and other perf. part info rt turbo Lancer 2 11-06-2002 02:46 PM
turbo sizing question sushi Forced Induction 1 04-15-2002 11:50 AM
