Go Back   Automotive Forums Car Chat > BMW > 7 Series
Old 02-07-2003, 10:05 PM
hsimms hsimms is offline
Transmission
Has anyone seen this problem before I have a bmw 570iL the transmisson won,t go in reverse when the car is cold. This is an automatic transmisson.
HDS
Old 02-13-2003, 12:22 PM
mnewguy mnewguy is offline
check out this forum you will get a much better response
http://bimmer.roadfly.org/bmw/forums/e32/
If you register you can do a search. The transmission on the 740i has many problems. The most common is the valve body. It has 2 plastic balls that float in a maze of tubes and are suppose to be too large to fit in some areas. Since they are plastice however they eventually will fit in the are they are not suppose to. Some common symptoms are it will run in * fine, but won't shift in E. Reverse does not work. Or will not shift or go in reverse, but once warm will work or after I stopped and restarted the problem went away. I am not sure if this will help you, but I am sure someone on the roadfly board will have had a similar problem as you.
Old 01-19-2004, 09:00 PM
middlebrookgt middlebrookgt is offline
I just had the "Pressure Regulator Bore" replaced in my 1994 740iL. I was told it is a Known Wear/Tear problem with these transmissions. The car would not go into reverse after driving about 40 miles (heating up), but if I jiggled it, it would eventually go into reverse - or after it was allowed to cool down. I got a rebuilt part installed for $489 by a shop recommended by my local dealer.The OEM quote from the dealer for the same part was $2380.
Mustang Transmission part 2001 lawg8r Mustang Problem Diagnosis 1 04-13-2009 04:24 PM
Changing Transmission mkcody88 Accord/TSX/Accord Hybrid 2 04-05-2009 01:50 PM
h22 sh transmission used as a regular transmission h22 Prelude 1 07-31-2004 11:32 AM
?Transmission Fluid Needed for Manual Transmission? 85BlueGTI Golf 1 05-31-2004 08:21 PM
1988 Z24 Transmission problem, torque converter wont lock after transmission change Dale24 Cavalier 4 01-23-2004 02:29 PM
