Old 02-04-2003, 02:14 AM
MEKANIK MEKANIK is offline
This sounds dumb, but.................?
This seems really stupid, but how long should you have to wait for the tamiya enamel brush paint to dry before putting on the next coat??
(I used it for the under body and interior.)
Also. When people say that they cut the front shocks to lower the car. Does this mean you cut a small segement out of the each shock/spring and then glue the top bit back on?? If so this would make the shocks much weaker, right??
Cheers guys
MEKANIK (Darren)
Old 02-04-2003, 02:22 AM
RallyRaider's Avatar
Zomby Woof
Hi Darren
I usually wait about a day but I am probably bit on the impatient side
Concerning the shocks. The trick is, after cutting them drill each end out and glue in a cut off pin. That way the new shock is even stronger than the original piece
Old 02-04-2003, 04:24 AM
druid_99's Avatar
druid_99 druid_99 is offline
For enamel paints I usually wait for a day or two, but usually it dries up after 6 hours... but depends on the brands I think...
Old 02-04-2003, 02:09 PM
It would be quite tricky to drill a hole in those shocks because they are so small and only measure like 3mm in diameter, right?? Do you actually need the pin or can you do without it?
Thanks guys
Old 02-04-2003, 03:05 PM
primera man's Avatar
"P-Man"
You could do with out, but both surfaces that are to be glued need to be very flat and clean.
Use a good superglue also.
The paint question....wait 1 day
View All My Models Here.
Old 02-04-2003, 05:16 PM
Guido Guido is offline
aha, confess, confess...
I had no clue on how to do that, but wasn't to keen to ask, since the occasion to do a lowering never arose. But now I know the trick, I think I might lower on of my next Merc's :jump:
Old 02-04-2003, 05:39 PM
magicmanjk808 magicmanjk808 is offline
Send a message via AIM to magicmanjk808
Thanks guys
i have done it without the pin, but it is quite weak and breaks easily if you aren't careful, sometimes even when you are careful. using the pin is much better.
Current Project:
Fujimi Toyota Altezza RS200
bye bye handles, moldings, rain gutters, license plate holders
View some pics of it here http://www.automotiveforums.com/vbulletin/t72123.html
Old 02-04-2003, 05:47 PM
"P-Man"
lol...like the ugly duck !!
Old 02-05-2003, 03:55 AM
Zomby Woof
Thanks guys
If there is no room for a hole large enough for a pin then just use some wire, anything that will take the sheer and tension forces.
Given the shock is 3mm, if you drill a 1mm hole for a pin or piece of wire then there shouldn't be too much problem. You'll need a pin vice and some very small drill bits to do this properly.
Old 02-05-2003, 04:06 AM
Purpura Delujo Purpura Delujo is offline
But now I know the trick, I think I might lower one of my next Merc's :jump:
Will you make it lay frame? Like this Benz?
Old 02-05-2003, 05:10 AM
Zomby Woof
May seem peculular to a man of your tastes Lowriders4life but the pin trick works equally well when increasing ride height!
Why would anybody want to do that you ask? WRC gravel or snow cars is the answer, for instance two of the three Peugeots in my sig were raised from the low tarmac height.
Old 02-05-2003, 05:20 AM
Sorry mate, I don't have a scale model of that 280SE. :finger:
But in a diorama why not?
This is going to sound dumb but... darryl2172 Grand Prix 3 09-11-2007 02:10 PM
Brawl in the wild...sounds dumb but pretty good!! ned032002 Videos 0 05-23-2007 10:02 PM
this is dumb but hear me out ntimeol Del Sol 1 01-29-2007 05:41 PM
May sound dumb but need help crimson65 Malibu 2 12-09-2005 04:32 PM
this may sound dumb but need a quick answer nickelfish19 Cavalier 1 03-21-2005 06:12 PM
