Old 02-03-2003, 09:30 PM
johnsonj2 johnsonj2 is offline
Question 97 Cavalier Kyeless Remote Programming
We have recently bought a new keyless entry remote for my 97 Z24 and we need to program it. We need directions for programming it for use.
Old 02-04-2003, 01:04 PM
92CivicVX 92CivicVX is offline
I have a 97 Cavalier, I bought it last summer and bought an alarm and keyless start with it. When I needed it programmed I got the info from the store that I bought it from. Go to the store you got it from and they should be able to hook you up with it.
R.I.P 92 Civic VX
1998 Pontiac Sunfire
Pioneer 6x9's in back
Pioneer 6' and 4x6's in front
Old 02-04-2003, 02:37 PM
Shortbus Shortbus is offline
Blah blah blah
Send a message via AIM to Shortbus
97 Cavalier Remote Programming
1. Turn th ingition switch to off
2. Jumper program connector terminal A to terminal B "door locks will
lock and unlock in approximately two seconds"
3. Press lock and unlock button on one transmitter. Door locks will lock and unlock in approximately ten seconds. The RFA Module is now programmed for the first transmitter.
4. Repeat step 3 using other transmitter if you more than one transmitter.
5. Disconnect jumper from program connector.
Hope this helps you out.
BTW The door lock receiver module is in the trunk on the drivers side. The pins are labled from A thru J 16 total. Make sure you just ground A and B together.
Old 02-25-2003, 07:47 PM
Unhappy Didn't Work
My husband has tried your suggestion several times and it did not work. The car never locks and unlocks the doors in order for him to click the remote. Any other suggestions?
Old 02-25-2003, 07:51 PM
Blah blah blah
I will see if I can find a picture of the connector at work and post it here. As long as the keyless system is a factory one this program procedure should work.
Old 02-27-2004, 07:02 PM
n8or9 n8or9 is offline
Re: 97 Cavalier Kyeless Remote Programming
wheres the picture i gave you a year
Old 03-08-2004, 09:43 PM
RollingRoc RollingRoc is offline
Send a message via AIM to RollingRoc
I was wondering if I could get some direction on finding the pins in my trunk. I looked everywhere and don't see anything that seems to be it. I bought a new keyless off ebay and my car had it before (97 Cavalier Z24). I thought maybe the Z24 might be different. I know that once you ground A and B you can program a new remote, but I can't find the pins in my trunk. Any help would be apopreciated (pics???), The dealers here want 80$...no way!!
Thanks,
Sean
Old 03-10-2004, 05:31 PM
OK my bad...I didn't look hard enough. I found the RFA. Now I tried the procedure and it didn't work. Istead my driver door doesn't work w/the power now, but teh passenger does. ANy help is appreciated.
2007 Honda Odyssey Keyless Remote Programming 2009mustang Odyssey 3 12-15-2010 11:29 PM
2007 Honda Odyssey Keyless Remote Programming 2009mustang Odyssey 1 08-25-2010 05:06 PM
How to put BCM into program mode? (Where is BCM/MALL fuse?) copchick527 Grand AM 5 03-02-2009 03:30 PM
2000 cavalier keyless remote programming mindlessntx Cavalier 1 02-25-2003 10:00 AM
