Old 02-03-2003, 06:49 PM
Vyacheslav's Avatar
Vyacheslav Vyacheslav is offline
Send a message via ICQ to Vyacheslav Send a message via AIM to Vyacheslav
Angry Tamiya compund, uh
I just bought it, came home. Since i dont have and couldnt find the 2000+ sand paper, i used wet 600 sand paper. Sanded a testing part a bit, took an old soft white shirt, put some compound on it, rub the wing.
First observations...: the paint went to the shirt right after 2-4 seconds of rubbing. Shirt left scratches on the paint, wing became worth than it was with orange peal.
God damn damn damn!!!
what did i do wrong?
Recently completed models:
JGTC Mobil 1 NSX
Porsche 911 gt2
1985 Toyota Corolla AE86
Old 02-03-2003, 06:56 PM
daggerlee's Avatar
You only used 600 grit sandpaper. That's what went wrong. Unless you rub for a really long time, you won't remove 600 grit scratches with Tamiya compound, which is probably like 8000 grit in terms of sandpaper, at least..
Dan
Integra14's Avatar
Integra14 Integra14 is offline
Send a message via AIM to Integra14
way to low of grit paper.. ... as said before, for comppound, you can't just Jump from 600 to compound.. you have to go from 1000-1500-2000 then compoudn... or something like that....... I used 1500 to compound and it was fine........
Old 02-03-2003, 07:00 PM
Vyacheslav's Avatar
I seem dont have much luck with sand papers around here. Hobby shop, no 1500+ grit sand paper. Wal Mart, no, other stores, no...
Geez, do i have to ask someone around here to send me a peice of high grit sand paper? i dunno...
JGTC Mobil 1 NSX
Porsche 911 gt2
Old 02-03-2003, 07:05 PM
daggerlee's Avatar
Try automotive supply shops, like Pep Boys, or R&S Strauss. Ask for their polishing section, and you should be able to find 2000 grit 3M sandpaper.
If not, you can order Micromesh online. Micromesh is better than regular sandpaper because it last longer and gives a smoother cut. Try www.micromark.com or www.micro-surface.com (beware the second store charges $10 shipping for something that could be sent in a frickin' envelope..)
Dan
Old 02-03-2003, 07:15 PM
Jay! Jay! is offline
Horizontally Opposed
Go to the laidies' nail cosmetic aisle in WalMart and look for sanding sticks that are like sanding cloths on foam. Find one that's like blue, pink, white and gray.
On mine:
blue: ~2,400 grit
pink: ~4,000 grit
white: ~6,000 grit
gray: ~12,000 grit
When you see 12,000 grit, you won't even believe it's got any texture at all...
Hierarchy of Subaru:
(Click to see mine!)
Old 02-03-2003, 07:22 PM
Vric's Avatar
Vric Vric is offline
Re: Tamiya compund, uh
Better than me.. after 5 minute of rubbing, noting moved...
Look like Tamiya compound is totaly crap.. I stick with Car Wax
Old 02-03-2003, 07:26 PM
daggerlee's Avatar
Re: Re: Tamiya compund, uh
It's not crap, you need to use it properly for it to have a good effect. How did you use it?
Dan
Old 02-03-2003, 07:31 PM
bah humbug's Avatar
I haven't tried it but I think it works since Pman uses it. His R34 in the gallery says he sanded it with i guess a high grit and then compounded it.
Old 02-03-2003, 07:32 PM
Vric's Avatar
Re: Re: Re: Tamiya compund, uh
1200 Sand paper (dont have less and dont think it worth buying higher grade.. take a white sheet.. cost less and is the same )
anyway Sanded at 1200 for long (I had buble on the paint) I get rid of them, then I tryed the compound.. ok the refelction come back, but you can see scratch of the sand paper.....
A real compound should get out the scratch on a budy... dont seem to do anything for me
Old 02-03-2003, 07:37 PM
bah humbug's Avatar
Pman used 2000 grit on his R34
Old 02-03-2003, 07:40 PM
daggerlee's Avatar
Re: Re: Re: Re: Tamiya compund, uh
Of course you'll see scratches, because you're not using a high enough grade sandpaper.
It's worth buying it at a higher grade, because that's how Tamiya sandpaper works. It's fine if you don't want to buy the higher grade sandpaper but it DOES work for 2000+. If you get better results with automotive waxes, fine, but don't call it total crap
Check out this Aristo, sanded with 2000 grit 3M, then polished with Tamiya compound:
Dan
clatescivicr clatescivicr is offline
I just use normal automotive compound.... works fine for me, You just have to not push to hard or it sands away the paint.
Clate - I'm back
Old 02-03-2003, 09:28 PM
Vyacheslav's Avatar
ok i used that nail thingy that jay offered. It sanded the peal off, fine, but when i polished it and got reflections etc, i can see small holes in paint.
JGTC Mobil 1 NSX
Porsche 911 gt2
Old 02-03-2003, 10:42 PM
935k3's Avatar
935k3 935k3 is offline
If you see holes you probably had some small bubbles in the paint which means you held the can a little to close. Tamiya's compound is a very good product. It works very well on their paints. It does not remove heavy orange peel. You need to get the sanding kit from Micromesh it starts at 1800 grit and goes to 12,000 grit. With most paint you start with 3200 or 4000 then 6000,8000,1200 then use polish. Some of the scratches are caused because the paint is not fully cured and needs more drying time. the 1800 grit and 2400 are good for sanding primers.
1/35 tamiya King Tiger EVILxRESIDENT Armor / Combat 0 09-13-2010 07:19 PM
Tamiya R33 skyline Wolf95 Completed Projects / Gallery 25 08-28-2010 05:46 PM
Tamiya Nissan GTR R35 Egil Completed Projects / Gallery 14 03-22-2010 12:45 PM
tamiya ferrari fxx DSheth Car Modeling 3 12-02-2009 06:40 PM
Tamiya Compund in the detail lines! gabbadude Car Modeling 7 11-12-2005 12:58 AM
