Old 02-01-2003, 11:02 PM
Vric's Avatar
Vric Vric is offline
Tamiya Compound
Hi
I just bouth some Tamiya Compound. I never used thatt before.. So I try ir on a spare body (My old Porsche Boxter) First.. compond seem to do nothing... I have made some scratch to "test" it.. and those scratch still there after rubbing compound for few minutes....
So does anyone can explain me how to use this ? Look like i'm still a newbee
Old 02-01-2003, 11:06 PM
bah humbug's Avatar
search the forum for "rubbing compound" I remember there were past threads about this. I also want tamiya rubbing compound, but can't seem to find it anywhere but the internet.
Old 02-01-2003, 11:07 PM
Integra14's Avatar
Integra14 Integra14 is offline
Send a message via AIM to Integra14
vric i have the same problem... didn't really do anythin! i want my money back!
Old 02-01-2003, 11:17 PM
daggerlee's Avatar
You need to sand the paint smooth with some high grit paper, at least 2000. Sand it until you can't see any glossy spots in it at all then polish.
Dan
TheSyndicate's Avatar
TheSyndicate TheSyndicate is offline
if it makes scratches then your paint isn't cured enough, or you didn't prime.
Old 02-01-2003, 11:21 PM
TURBO_EK4's Avatar
TURBO_EK4 TURBO_EK4 is offline
Send a message via AIM to TURBO_EK4 Send a message via Yahoo to TURBO_EK4
The compound didnt make the scratches, He made the scratches to test the compound.
//Romeo\\
Newbies, Please Read This.
Old 02-02-2003, 02:07 AM
hirofkd's Avatar
hirofkd hirofkd is offline
In order for the compound to do its job, the surface has to be sanded.
Here, the hood is partially sanded with 2000 grit sand paper.
Now, when the hood is thoroughly sanded, it should look like this.
After compound is used, you get a result like this.
Of course, there are more to it, but I can't disclose everything.
Hiroaki Fukuda
Old 02-02-2003, 03:07 AM
tazdev's Avatar
tazdev tazdev is offline
I'm still here
meanie
come on do tell, or do we have to get Pman to spill the beans?
Old 02-02-2003, 03:20 AM
Ragnarok043's Avatar
Ragnarok043 Ragnarok043 is offline
Send a message via AIM to Ragnarok043
you should understand that compound is like high grit sand paper. it cant remove deep scratches without stepping up the grits gradually.
Old 02-02-2003, 08:13 AM
Vric's Avatar
yea I know.. but it was a small scratch just for test.. I got hard time to remove finger print..
Look like I will still use Car Wax...
Old 02-02-2003, 03:11 PM
bart8016 bart8016 is offline
Could someone please make A plan in witch steps I have to do to make my car good shining when the body comes straight out of the box and there's nothing done with it.
Greets Bart
Greets,
Bart
Old 02-02-2003, 03:28 PM
BWheel BWheel is offline
Tamiya Compound is about equal to 8000 grit or higher paper. Here's what you do:
Spray your body.
Let it cure. If you think it's cured long enough, leave it another day.
Check out the orange peel. Think about giving up modelling... ;-)
Now, start cutting Start with 1200grit, get the finish flat, no dimples.
Step up the grit (Normally, I move to 2000 now)
4000 grit
8000 grit
12000 grit or polishing compound. Get a truly amazing finish.
NOW use Wax.
Thing to note - do not sand hard. You'll get through the paint. If you use clear coat, if you end up with color on your sandpaper, you've gone through, I would re-clear coat at this point, and start again.
If you have sanding marks at a level, you will not get rid of them - you will have to go back to the start, and go through it all again, from 1200 right through.
Take it slowly. Do a panel at a time, don't try to do a full body. Also, when you've sanded it PROPERLY, you won't leave fingerprints on the body.
Good luck....
Old 02-02-2003, 03:47 PM
Vyacheslav's Avatar
Vyacheslav Vyacheslav is offline
Send a message via ICQ to Vyacheslav Send a message via AIM to Vyacheslav
do you have to use wax with sandpaper or a soft old shirt?
Recently completed models:
JGTC Mobil 1 NSX
Porsche 911 gt2
1985 Toyota Corolla AE86
Old 02-02-2003, 04:06 PM
Wax with sandpaper? Ermm... no, sorry if there's confusion.
Do all your sanding then, when finished, you'll want to wax. With a shirt, or cloth or similar.
Of course, you CAN get away with the wax after this process, 'cause you have such a great shine, but I find that a waxing just gives it that better bit of a glow.
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 01:41 AM
