Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 01-29-2003, 06:14 PM
3rdchild 3rdchild is offline
cross drilled or slotted?
Whats better, cross-drilled, slotted or both? I've noticed that swapping brakes for 300zx brakes are pretty popular, is it better than getting an aftermarket brake kit?
Old 01-29-2003, 08:00 PM
natedogs911 natedogs911 is offline
Both would be the best,
cross drilling helps it disapate heat more efficiently and slotted rotors channel dirt and brake dust away, i'm sure there's a lot more but in a nut shell that's it.
the z32 brake conversion is so popular because the breaks on the 240sx well, suck.
the z32 TT rotors are 30 mm
and the non-turbo are 26mm
plus the calipers are 4 piston instead of the single piston calipers on the 240
if u don't wanna do a full conversion and do a 5-lug swap SRswap.com
has for $849 has the z32 brake conversion for the front drilled for a 4-lug with brembo cross drilled and slotors rotors plus stock replacement brembo cross drilled and slotted rotors in the rear
that's what i'm gonna get
or for 500 you get just the front conversion
Old 01-29-2003, 08:11 PM
NISSANSPDR's Avatar
NISSANSPDR NISSANSPDR is offline
Send a message via AIM to NISSANSPDR
Both I'd say...Brembo is the only way to go...or any other reputable Brake System manufacturer
Yours truly,
Gabriel
Old 01-29-2003, 10:53 PM
Suislide's Avatar
Suislide Suislide is offline
both. Brembo, Endless and Project Mu all make awesome brakes for 240SX.
-Brian
2013 Subaru BRZ Sport-Tech 6MT. Not stock.
Old 02-07-2003, 01:25 AM
siege35 siege35 is offline
Send a message via AIM to siege35
This is incorrect. ONLY the 1990 z32 non-turbo calipers are 26mm (aluminum). The 30mm aluminum calipers were used on all 1990 twinturbos and all 1991-1992.5 Z's (NA and TT). 1992.5-1996 NA and TT all use 30mm iron.
Also for those suggesting Brembo, Project Mu, etc...I'd really like to know what you're using your car for, because I've never heard of any 240 owners having problems road racing with stock Z32 calipers.
Old 02-08-2003, 02:54 PM
thanks
thanks for the correction
i didn't know that
FS: Brembo Cross Drilled/Slotted Rotors irotors.com 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 2 05-09-2002 02:28 PM
FS: Brembo Cross Drilled/Slotted Rotors irotors.com Classifieds 0 05-09-2002 06:20 AM
cross-drilled/slotted or just slotted SFF900 Engineering/ Technical 2 02-15-2002 02:38 PM
Crossed drilled/slotted rotors. kris Engineering/ Technical 14 01-26-2002 03:31 PM
