Old 01-29-2003, 04:24 PM
Camber's Avatar
Camber Camber is offline
Send a message via AIM to Camber Send a message via Yahoo to Camber
Tamiya Semi-gloss Acrylic for Frames?
Do I use the Tamiya Acrylic bottles of semi-gloss for window trim or will it bleed through? Or should i spray some Laquer Black and do it with a brush? Tanks
Old 01-29-2003, 04:40 PM
ales's Avatar
ales ales is offline
Forza Schumacher
If you're planning to airbrush it - it will be fine, just use lower pressure and go over it several times.
If you're planning to paintbrush the X18 acrylic - more likely than not it will bleed under the maskin tape.
Old 01-29-2003, 04:44 PM
Camber's Avatar
So your saying if i use tamiya acrylic with Tamiya Tape it WILL bleed? You made that sound to complicated.
Old 01-29-2003, 04:48 PM
ales's Avatar
Forza Schumacher
It will bleed if you try to brushpaint it. If you airbrush it - it won't bleed. What's so complicated?
Old 01-29-2003, 04:53 PM
cph81's Avatar
cph81 cph81 is offline
Yes, the Acrylic paint might bleed alittle, but you can wash off the bleed paint right away. I always use acrylic paint for windows trim.
Just Finished:
Old 01-29-2003, 04:56 PM
Camber's Avatar
Ales - That that is is that that is'nt is'nt... Don't get Coy..
Cph - B4 or after it dries?
Old 01-29-2003, 04:58 PM
ales's Avatar
Forza Schumacher
Old 01-29-2003, 04:59 PM
Camber's Avatar
Originally posted by ales
I'm only bustin.. Thanks for the help.
cph81's Avatar
Just don't put it aside too long after dry. After you peel the tape off, wash them out with a cotton swab.
Just Finished:
Tamiya TS-79 semi-gloss clear question zak78 Car Modeling 4 11-25-2007 07:51 PM
Trouble with Tamiya X18 Semi-Gloss Black and Sanding question Katsura Car Modeling 6 06-15-2006 12:59 AM
Question anout Tamiya semi-gloss black spray paint for the body. (ive done a search) MEKANIK Car Modeling 3 09-15-2003 04:45 PM
Semi gloss black... hermanchauw Car Modeling 8 01-20-2003 02:27 PM
Tamiya Semi-Gloss Black X-18 / Air Bubbles djmr2 Car Modeling 12 07-01-2002 12:48 AM
