Old 01-29-2003, 01:22 AM
slickrick slickrick is offline
pls help with accord problem
I have a 1986 Honda Accord Lxi. After 10 minutes of driving the programmed fuel injection comes on. The cars performance does not suffer however it then starts to idle at 1100 rpm instead of the usual 800 rpm. Any suggestions on what the problem could be is greatly appreciated.
Thank you.
A perfection of means but confusion of ends characterizes our generation.
Old 01-29-2003, 09:17 AM
thomas crown's Avatar
thomas crown thomas crown is offline
Send a message via AIM to thomas crown
i've got the same car with the same issue, except the light comes on sometimes after driving 2 blocks, and sometimes after driving 20 miles. i have never noticed any change in performance and i had it tested one time and i was told it was okay to drive with it on and that it wasn't serious i guess. hopefully it's not because the first time it came on my car had around 135,000 miles and now i'm at 192,000 and it comes on everytime i drive... hopefully somebody has an answer
t.c.
'72 AZ600 Coupe
'86 Accord Lx-i (currently 210,000 miles)
'90 CRX Si
'93 del Sol Si
'95 Accord EX (all show)
'03 Civic EX (45,000+ miles)
Old 03-01-2007, 10:52 PM
RaceReady86accord RaceReady86accord is offline
Re: pls help with accord problem
hey man it could be ur fuel injectors if im correct or when the car warms up crack might be speading and u might have an air leak... but then im not really sure, im just trying to help you out.
pls help with check engine light tried alot of things p0740 l@@K excoupe23 Technical 0 08-19-2007 03:55 PM
pls help with tires Ukrainian Tires and Wheels 2 08-31-2006 06:26 PM
2002 Accord 4 CYL New Owner Needs Help with Engine Problem (Stalling and Maint. Light ncpmedic Accord/TSX/Accord Hybrid 4 10-18-2005 05:35 PM
2002 Accord 4 CYL New Owner Needs Help with Engine Problem (Stalling and Maint. Light ncpmedic Let's get Technical! 1 10-17-2005 12:46 PM
Pls help with wheel-tire combination deeknow Tires and Wheels 2 11-28-2003 11:14 AM
