Old 01-28-2003, 03:21 PM
flyingmachine flyingmachine is offline
any one here use future floor polish?
I use this stuff alot for my planes, adding a little tamiya flat base, I can have flat clear too. So how's future for cars? can it be polished and shined like tamiya or other brands of clear finished. At $2.49 for lifetime supply, it can't be beat.
Old 01-28-2003, 03:26 PM
ales's Avatar
ales ales is offline
Forza Schumacher
Haven't used it personally, but here are a few threads that I found for you that might help you with your question.
http://www.automotiveforums.com/vbul...ghlight=future
HTH
Alex
Old 01-28-2003, 03:54 PM
crab's Avatar
crab crab is offline
Yeah I used it for my clk dtm..... u need a dozen coats before the mirror effect can be seen..... but then, i use a cotton swab to apply the stuff. Most ppl recommend a big flat soft brush so depending on how u apply Future it may or may not require as many coats.
Several gripes i have with Future and cars:
1. Wait at least 1/2 hr between coats..... cuz the stuff dries like jello and then hardens over time... if u dont' wait long enough, u'll end up "peeling" the earlier coats, creating this messy, stick yellow blob... wash up with water and try again (if it hasn't already messed up ur paint job)
2. Doesn't like water... turns yellow/brown with water for some reason, so don't bother using a wet towel to wipe off the excess... use ammonia to do that
3. I couldn't get Future to work with my airbrush... though most ppl say they have...
That's my $.02 on Future and cars
My CLK DTM in the AF contest (first thread) has several layers of Future on it... check it out, and if u haven't voted yet..... (wink wink)
Referring to pictures of *his* 996 Carrera 4...
"Why would I want to post it in the 996 section if its a 911 that I have[own]??? :huh: :huh: :huh:..."
- sizzilinS7
Boy: I pry apart that battleship you call your ass.
Boy: I see shit nuggets hanging from the hair around your asshole.
Girl: WTF?!?!?
Boy: They stink really bad.
Girl: OMG STOP!!!
Boy: I start to get fed up with your ugly ass
Old 01-28-2003, 04:16 PM
RallyRaider's Avatar
Zomby Woof
Yeah, I use future from time to time. Actually I use the Australian equivalent which is Johnson's Magic Shine. Never tried to airbrush it but wipe it on with a cotton bud, or tissue. Use it mainly on clear surfaces to seal in decals. Only ever used it on a car body once, have deen scared away from using it any more by a few horror stories of cracking over time. That said the one car I used it on has not cracked after almost three years!
Old 01-28-2003, 04:22 PM
daggerlee's Avatar
I used to use Future for car bodies, but now I think a good lacquer clear coat is less time consuming. With future, you have to apply many coats and wait for it to dry, with a lacquer you can just spray on two or three coats and polish it in a few days. Now I use Future to create good flat/semi gloss coats, and to clear small decal'd parts.
Dan
Old 01-28-2003, 04:56 PM
djmr2's Avatar
djmr2 djmr2 is offline
I have used future on car bodies as well. The stuff is really thin so you'll need at least a good 10+coats before u can polish/sand it to a brilliant shine..
I airbrush mine. It's a cheap alternative to lacquer clear coats, but like daggerlee says, u can put like 3 coats of lacquer clear on and your set..
on the plus side, future is acrylic (less harmful), smells better than lacquer too!
Any one here use, fuel filter instead oil catch can ? Killa Engine, Transmission and Drivetrain 16 07-17-2006 01:18 AM
Any one here have an enzo here?? Vicious 288 GTO | F40 | F50 | Enzo 14 12-08-2004 03:35 PM
Any one here using HAYNES book to repair car ? Killa Off-Topic 9 09-17-2004 06:14 PM
future floor polish... a million and one uses? Kosmonaut Car Modeling 3 06-17-2002 06:06 PM
Any guys here use or know abt JVC KS-AX6500? Integra-F20C Car Audio 2 02-26-2002 03:43 AM
