Old 01-23-2003, 02:19 PM
Vyacheslav's Avatar
Vyacheslav Vyacheslav is offline
Send a message via ICQ to Vyacheslav Send a message via AIM to Vyacheslav
Painting + clear coat
After i spray couple coats of paint, should i spray clear coat right after? or wait untill it dries?
Recently completed models:
JGTC Mobil 1 NSX
Porsche 911 gt2
1985 Toyota Corolla AE86
Old 01-23-2003, 02:21 PM
Integra14's Avatar
Integra14 Integra14 is offline
Send a message via AIM to Integra14
after u paint. Wait 7 days until u clear coat.. tahts what i do..
Old 01-23-2003, 02:30 PM
SuPeRcAr_MaN's Avatar
SuPeRcAr_MaN SuPeRcAr_MaN is offline
Im a newbie... Are primers and clearcoats easy to find at a hobby store??? What should I look for when buying them???
Old 01-23-2003, 02:31 PM
Vyacheslav's Avatar
hope the dust wont get on the body after 7 days
thanks
JGTC Mobil 1 NSX
Porsche 911 gt2
Old 01-23-2003, 02:32 PM
tazdev's Avatar
tazdev tazdev is offline
I'm still here
wait at leats 7 days so as to avoid bubbles in the paint
Old 01-23-2003, 02:47 PM
freakray freakray is offline
AF Modelrater
Which is the reason why you cover the model while it is drying, once the paint is completely dry you can wash any possible dust off like you would wash the model before you start painting.
Usually you can find them in the same section as all the paints, often on the same rack as the paints.
Welcome to AF BTW
AF User Guidelines
Old 01-23-2003, 02:49 PM
ales's Avatar
ales ales is offline
Forza Schumacher
I'd say it depends on the paint you'll be using.
You just wash it.
You look for rimer and clear laquer! If the hobby store carries Tamiya spraycans, they should be able to have primer and clear as well. I suggest you use Tamiya paints when you start modelling as they are reasonably fool-prof (look at P-man's models! :right: ).
Alex
edit: Ray -
Old 01-23-2003, 02:54 PM
Vyacheslav's Avatar
so i should wash my model with primer before paint right? and dry it and paint it, couple coats. then wash it again. thanks
JGTC Mobil 1 NSX
Porsche 911 gt2
Old 01-23-2003, 03:14 PM
MEKANIK MEKANIK is offline
Once you've waited 7 days for the paint to dry, do you have to give it a light sand before the clear coat or can you just wash it and then spray the clear on.
cheers guys
Old 01-23-2003, 03:27 PM
ales's Avatar
Forza Schumacher
cheers guys
Depends on how good the paint turned out. That is, if you're not using metallic colours. If you are - leae tha paint alon.e It's in the FAQ.
Decals - Clear coat & Sanding grit Zman007 Auto Collision Network 1 12-24-2010 07:52 AM
Need Painting help. Glaringlizard Car Modeling 3 08-14-2010 07:38 PM
Gloss Clear Coat vs. Matte Clear Coat deltableh Car Modeling 7 04-05-2006 12:24 AM
Panellines disappear after metalic paint + clear coats...... yellow15 Car Modeling 4 06-11-2003 07:19 PM
Help...Clear Coating over Enamel Paints ??? Hiroboy Car Modeling 1 02-26-2003 07:27 PM
