Old 01-23-2003, 11:26 AM
Dallas_Fl Dallas_Fl is offline
Send a message via AIM to Dallas_Fl
Does anybody have a Turbo?
did you get a kit or did you buy everything seperate? what peices would I need to run a D16 with 10psi.
Old 01-23-2003, 11:31 AM
tbk49's Avatar
tbk49 tbk49 is offline
Send a message via MSN to tbk49
thats beyond internal support, you gonna need to build inside the block
blah
Old 01-23-2003, 11:33 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
you can use a 92-95 turbo kit from Greddy or FMAX. or for a cheaper route you could build yourself a turbo kit vafc info . somewhere in the middle (price wise) would be to build your own but using hondata instead of vafc controlled
there are a few different options. it depends on your budget and the gain you are looking for
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 01-23-2003, 11:35 AM
amy@af's Avatar
the build your own kit (aka junkyard) can handle 5-9 psi on stock internals. you could stick a thicker head gasket on if you were worried
Old 01-23-2003, 11:38 AM
dropshop dropshop is offline
Send a message via AIM to dropshop
here is my kit i sell
TURBO PARTS [1] RETAIL
Turbo T3 .60 trim Rebuilt T3 .60 trim $450
Manifold (2)Flange's (2)L's (2) T's (1) Rec bar $250
Piping (2)180 2" (3)180 2.25" (1)45 2.25" $150
Drain Flange(drain) Bung (1/2npt) $50
Oil Feed lines and tees 4an to bspt 4an90 4an45(2) 4anstr(1) $200
Drain Lines 10an to 3/8npt 10an45 (2) 10an-1/2npt
RRE hoses (2)2", 2.25", 2.25 to TB $60
Intercooler 2" In 2.25" out Extrueded alum core $450
Injectors 450CC DSM Eclipse (1g) $120
BOV Eclipse BOV (1g) $50
BOV flange cnc machined flange $20
Flex pipe Mild steel (SS available) $55
Exhaust DP and flanges 2.5" mandrel bent TIG welded $170
Hondata Stage2B (S200) $550
TOTAL PARTS $2,610
hi im jon and im addicted to boost
Old 01-23-2003, 12:58 PM
91civicDXdude's Avatar
i belive that anything over about 5psi on stock internals is only fun for about the month that your engine lives
Old 01-23-2003, 01:07 PM
kris's Avatar
kris kris is offline
Off playing with fire.
I can get you a Starion turbo, and intercooler for decent price.
Old 01-24-2003, 09:49 AM
that is the most retarded statement yet
first off iran 11 psi NON ic on a 250000+ mile D16 for 8 months with NO issues then i sold that motor for $250 and now its in a crx running strong STILL
then i put in my zc
i run that @12 psi all day every day and have for over a year
i beat hte shit out of my car ........ ANYONES meotor that blows under 12-14 psi is because of POOR tuning
oh BTW i made178 whp and 176 ft lbs of tq on my ZC w my vafc hack
and now w the hondata its 190 whp and 185 ft lbs
Old 01-24-2003, 10:05 AM
slammed89civic's Avatar
slammed89civic slammed89civic is offline
Send a message via AIM to slammed89civic Send a message via Yahoo to slammed89civic
NIICE dropshop, i;m hoping to see similar results with my z6 (junkyard turboed, with jg pistons, rods, intake mani, gude mild mod cam, p&p head, and knife edged crank....what do you think i will produce at about 10-12 psi?
94 Integra LS, autotragic, Tons of mods
93 Accord wagon, Manual conversion and f20b swap in the near future!
Old 01-24-2003, 10:11 AM
what turbo and what fuel management u usin?
Old 01-24-2003, 02:09 PM
i've just always heard from the guys at the d series ezboard that anything above 5 psi on stock internals is a no no..
Old 01-24-2003, 02:17 PM
amy@af's Avatar
i've know dropshop quite a while now. probably close to 1 1/2-2 yrs. what he said about his engines is true. i can't speak for what others have told you.....but as for dropshop, his words have been proven through time and dyno sheets.
Old 01-24-2003, 04:30 PM
turbcivic's Avatar
turbcivic turbcivic is offline
We just yanked out a SOHC Vtec engine out of a HB today at work becuase it had bad rod bearings and i'm planning on taking the engine and rebuilding it for a turbo and put it in my car. I plan on running it on the street daily with about 10-14 psi. I thinking a 8.5:1 Cr pistions and upgrading the engine while it is at work or in my garage. Would a T3 turbo be to big for the street? What type of engine mang. should i use?
Couple other questions, when i do the swap, what am i gonna need? The car is a 91 HB STD. Would the 91 si trans match up? Should i just get a 92 Si wiring harrness for the car? So many questions.
2007 dodge ram hemi sport-the tow/dd
1993 Civic HB-h22 with type s pistons, 125 shot, and some other goodies
1989 CRX(in the works)-h2b plus maybe some spray, or some boost
Old 01-24-2003, 05:16 PM
a T3 60 trim is what you want
for your application if you plan on DRAGRACING i say get a
.63 turbine A/R and for a street car get a .48A/R
if u need an explanation let me know
Old 01-24-2003, 05:54 PM
turbcivic's Avatar
No, i know that type of stuff. My car is a daily drvier that is going for SPL comps and raced very little. I just want something so i can screw with people a little. Just wanna break a 14.9
does anybody have a turbo kit for a BMW 1985 318i ? evo2885 3 Series 4 02-07-2006 03:37 PM
Does anybody have a B16a2 they want to sell? jmott83 '71-'87 Civic | CRX 2 06-09-2002 06:33 PM
does anybody have a e brake cover on their civic? rendog24 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 04-14-2002 05:29 PM
Does anybody have a body kit? essex '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 03-02-2002 01:39 PM
