Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 01-21-2003, 04:59 PM
Robdog Robdog is offline
Question Front Strut Tower Bar for 92 Maxima
Does anyone know where i can find the front strut tower bar for a 92 maxima with the DOHC engine? All i've found is the one for the SOHC.
Old 01-22-2003, 06:27 PM
Paonessa Paonessa is offline
i don't think it makes a difference
Old 01-23-2003, 12:43 AM
dmontzmax dmontzmax is offline
Send a message via AIM to dmontzmax
The DOHC motor sits higher. You will want to buy yours here
www.courtesynissan.com
make sure you get the 2k2 bar.
Old 01-23-2003, 12:20 PM
that's true but the bars are adjustable. so all you have to do is extend the end mounting brackets a little and it should fit. but if you find a more specific application get that one
Old 01-23-2003, 01:48 PM
You dont understand, the 92-94 SE has a BIG motor, and will have clearance issue with ANY bar on the market, it will hit the a/c hose and rub the manifold. ALL FSTB's on the market have been tested and only one has been found to work the 2k2 Maxima's bar, cause there engine is big as well. Unless you can find the OLD Courtesy Nissan bar that was made for the VE engine itself, but they dont make them anymore and havent for a few years now.
Old 01-24-2003, 03:38 PM
I looked at courtesy nissan's site, and i couldn't find any 2k2 bar. I found the one for 2k-2k3. Is this the right bar?
Old 01-24-2003, 04:02 PM
That is it, the one with the posts going straight off the bracket, that one is perfect.
Old 01-24-2003, 05:05 PM
And it just bolts on right? Sorry i'm unfamiliar with maxima's, I just got mine 2 weeks ago.
Old 01-24-2003, 05:10 PM
yup, if you look under the hood there is 3 strut tower nuts on each side, you take them off, put the FSTB around the bolts and put the nuts back on (so the fstb is like a big washer) torque it down to 18lbs I believe and you are done, I can put them on and take them off in less than 1 minutes very easy and the car feels alot different with them on.
Old 01-24-2003, 05:30 PM
Thanks! Now if i can just get my car running right I might be able to really test it out. I think my Mass Air Flow Sensor is defective, at least that's what the shop said when they checked the computer code. I have one on the way but it won't be in until next week!
Old 01-24-2003, 06:35 PM
I see you are in downey, you should roll out to the SoCal meets.
Old 01-27-2003, 04:55 PM
Let me know when the next meet is, that way I can check it out.
Old 01-27-2003, 05:01 PM
check, www.maxima.org in the west coast section. There is a All Nissan Meet going on in Cypress on Feb. 15th. Should be some tight cars there.
Looking for a Front Upper Strut Tower Bars dd23149006401549 Achieva 1 09-17-2009 05:39 PM
Looking for a Front Upper Strut Tower Bars dd23149006401549 Grand AM 2 09-17-2009 05:31 PM
"Generic" Strut Tower cross Bars? RidingOnRailz Engineering/ Technical 3 06-15-2009 11:40 AM
Matrix front strut tower bar for 5th Accord Provocateur Accord/TSX/Accord Hybrid 1 03-14-2002 04:42 PM
2001 Accord Front Strut Tower Bar... Any Recommendation?ons tech_101 Accord/TSX/Accord Hybrid 9 01-03-2002 07:42 AM
