Old 01-21-2003, 10:04 AM
slikk's Avatar
slikk slikk is offline
Send a message via AIM to slikk Send a message via Yahoo to slikk
wireing diagram
hey i need a major favor .. does anyone have the wireing diagram for the stock radio of a 94 tegra .. its has 16 pins.
or better yet tell me where i can find a wireing harness for the the car ... the side that is in the car not the side that is on the radio
much thanks
--drive it like you stole it--
Old 01-22-2003, 07:42 AM
turbcivic's Avatar
turbcivic turbcivic is offline
Specifications
Model Depicted '94 and up
Radio Size Din Unit
Console Size Double Din
Number of Channels 4
RMS Power 12 Watts / Channel
MAX Power 30 Watts / Channel (approx.)
Antenna Harada Antenna FM-93G
CD Controller? Yes
Main Power Wiring
Power (ignition) Yellow/Red
Power (constant) White/Blue
Power (antenna) Yellow/Green
Illumination Red/Black
Ground Solid Black
Front Speaker Wiring
Right Front (positive) Red/Green
Left Front (positive) Blue/Green
Right Front (negative) Brown/Black
Left Front (negative) Grey/Black
Rear Speaker Wiring
Right Rear (positive) Red/Yellow
Left Rear (positive) Blue/Yellow
Right Rear (negative) Brown/White
Left Rear (negative) Grey/White
Plug Pin Layout
Note: I haven't had a chance to double-check this diagram.
Background Information
The Integra's stock radio has three main connectors. One for the Antenna (which is a fairly standard plug), one for the main wiring harness (which has 16 pins, 13 of which are used), and another for the optional 6 disc CD changer (which has 8 pins). For a full description of each pin of the DIN connector (can be interfaced with Alpine CD Shuttles) please see the CD Shuttle DIN Layout page.
Rear View of Radio
| Antenna | Main Harness | CD Changer |
To zoom in on a specific connector, simply click on the item you wish to see.
Website here
http://www.integracaraudio.com/carau...agrams/wiring/
Old 01-22-2003, 08:39 PM
slikk's Avatar
much love dunn
a million thak to u sir i really appreciate that
Old 01-23-2003, 01:59 PM
turbcivic's Avatar
No problem. Were is CT are you from?
2007 dodge ram hemi sport-the tow/dd
1993 Civic HB-h22 with type s pistons, 125 shot, and some other goodies
1989 CRX(in the works)-h2b plus maybe some spray, or some boost
Old 01-23-2003, 03:04 PM
slikk's Avatar
i live in da port .. (bridgeport)
Old 01-23-2003, 03:09 PM
turbcivic's Avatar
Tight, i used to live in Groton when my dad was stationed there.
1997 Clio Airbag + wiring diagram casahit Clio/Clio II/Clio III 1 12-03-2010 04:54 AM
parts diagrams redka88 Liberty 1 05-12-2010 02:44 PM
1989 S-10 Blazer Wiring Diagram 89S10Blazer S-10 1 01-07-2010 10:01 AM
65 GMC tail light wiring diagram dcarreno2006 General Discussion 0 08-10-2009 11:13 PM
Anyone have diagram of spark plug wires diagram for 98 transport? saavedras_girl Trans Sport 2 01-13-2005 08:58 AM
