Old 01-21-2003, 09:46 AM
oreilly oreilly is offline
91 integra RS motor
Whats up I have a question?
Has anyone out there ever put a 91 RS motor in there civic?
If so please give me some pros and cons.
The reason I am choiseing this motor is I am getting the hole car for nothing. I can pretty much tear the teg up, and I am sure I will have all
the spear parts I will need. Please if anyone has done this swap let me know was you happy with it, was it difficult, what about wireing?
Please help me out!!!!
Thanks
Old 01-21-2003, 09:59 AM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
To put in a 91 teg engine also known as the B18A engine, you will need to get aftermarket Mounting brakets because the stock brakets on either car will not fit, and you will need to get shifter linkage or take the shifter linkage off the teg and cut it about 2 in. and reweld it back on.
Also, note, that if your car is a DX, or a STD with Dual Point Fuel Injection, you will have to convert over to Multi Point fuel injection.
The parts that you can use off the teg are:
-Engine
-Tranny
-Axles
-ECU
You can use HaSport Motor Mounts or HCP Engineering MOunts, i think HCP are better because they have 4 mounts including the mount on the fornt crossmember and the HaSport does not.
Someone else can add to this if i missed anything..
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Old 01-21-2003, 10:18 AM
91zc 91zc is offline
Dont forget to get the rear motor mount bracket from the integra. The swap is cake in an Si, Hf, or Ex. It is a little more work in a std/dx because you have to convert to a multipoint fuel injection system. Other than getting aftermarket mounts and shift linkage there is not a lot that is needed. I would however replace alot of the wear and tear parts before you install the engine.
91 civic 4dr
b16a
14.8@94
Old 01-21-2003, 03:09 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
don't forget to swap out the rear disk brakes while your at it
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 01-21-2003, 03:14 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Not only that but u also have to replace the hubs.
Old 01-21-2003, 07:51 PM
MyFirst4G's Avatar
Yea, and then put your drums on the the teg and sell it, like Ami did!! HAHA, thats so funny, i'd love to be the mechanic who replaces that guy's brakes!!! HAHAHAHA, i'd just laugh at the guy!!!
88 DX Hatch SOLD!
96 Saturn SL2:
91 DX Hatch:
Official 4th Gen OG
Hype Race Crew
Old 01-22-2003, 06:52 AM
91 integra RS motor
Thanks for the feedback!!
I will be taking it out of the teg as soon as the weather warms up a little. I mean shit it's like zero out here in easton mass.
Were can I pick up those HCP mounts?
Thanks again.
Old 01-23-2003, 05:33 PM
I have another question,
will I have to use the ecu from the integra or can I use one from a si
and if I have to use the one out of the teg will the clips from the stock dx ecu fit I know some wiring is involved also is there a wiring harness to convert this over?
Can anyone point me to a web site that might have more info on any of this?
sorry about all the questions but I would like to have some information
about the swap befor I go start doing it and get in a smellie situation
Old 01-23-2003, 08:40 PM
MyFirst4G's Avatar
Hey, we are here to help bro, i think if its obd0 like our cars are, then you wont have a problem, and i'm pretty sure that the 91 teg's are obd0 so the ecu should fit in fine!
88 DX Hatch SOLD!
96 Saturn SL2:
91 DX Hatch:
Official 4th Gen OG
Hype Race Crew
Old 01-23-2003, 11:54 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
That is one thing i would make sure you do while you have everything apart and out. Like the axles, i would go ahead and replace those while you have them out, save some trouble later down the line when they break...well unless the current ones off the teg don't have much wear. Im plannin on doin this swap also, so everyones replies will be helping me out also.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 01-24-2003, 12:03 AM
MyFirst4G's Avatar
So then i'm deffinatly gonna stop replying in this post........
Just Kidding lol! u know i'm kiddin
88 DX Hatch SOLD!
96 Saturn SL2:
91 DX Hatch:
Official 4th Gen OG
Hype Race Crew
Old 01-24-2003, 12:20 AM
91civicDXdude's Avatar
just a reminder that the b18 non vtec makes the most torque of any b series. even though you dont have the benefit of VTEC, you will still have a fast car. BTW, b18 has a lower compression ratios than other b series VTEC engines so it makes a perfect candidate for boost.
Old 01-24-2003, 07:11 AM
redmanjd redmanjd is offline
converting a dx to a b18 isnt hard i did it to my 90 dx i put a b18b1 in it. And i recommend you use the b18 ecu and yes your harness will plug into . Now i have hear that you cane use the 91 teg side post and mount but i just wet out and got azracing billet mounts they were 350.
it is a good idea to get new axles, timing belt, clutch ,throw out bearing, and a basic tune up.
90 civic hatch
b18b1
new crank , bearings
eagle connecting rods
je 10.5:1 pistons
milled .030 head
dc sport header
revolution catback
8lb flywheelstage
2 clutch
obx adj cam gears
spoon ecu chip
1990 acura integra motor??? 1990civic '88 - '91 Civic | CRX | Wagon | Shuttlee 48 05-15-2004 01:55 AM
installing integra motor mounts integra111 Integra 5 06-26-2003 09:09 PM
Will A Acura Integra Motor Fit In A Mustang Cobra machinehunter Car Modeling 12 05-04-2003 12:35 AM
'91 Integra motor in '89 Civic... NEED HELP Please jparsell82 Engineering/ Technical 2 06-18-2002 09:43 AM
'89 Civic with Integra Motor.... QUESTIONS?!? jparsell82 '88 - '91 Civic | CRX | Wagon | Shuttlee 0 06-15-2002 07:50 AM
