Old 01-21-2003, 01:59 AM
fwdfreak's Avatar
fwdfreak fwdfreak is offline
Send a message via MSN to fwdfreak
question about tamiya compound
Do I need to wet the cloth to use the compound or not? and do I need to do a lil sanding before attackin orange peel with the compound
Old 01-21-2003, 02:13 AM
hirofkd's Avatar
hirofkd hirofkd is offline
You don't necessarily have to wet the cloth, but occasionally, you might want to moisten a bit.
Polish without sanding, then sand other area and polish it to compare both.
I believe the later will give more sheen on the surface, but just try and see it for yourself. Of orange peel isn't so bad, you might not have to sand.
Hiroaki Fukuda
Old 01-21-2003, 07:04 AM
fwdfreak's Avatar
thanx man..
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
