Old 01-20-2003, 08:58 AM
joecwlaw's Avatar
joecwlaw joecwlaw is offline
Question help on Tamiya Subaru WRX 98 WRC
guys, I need your help. The cap at the roof which I highlighted, the manual said it should be painted in white. I am wondering after i put primer on the WRX, then what I should do?
procedure #1: paint the mica blue, put all the sticker, then put the white color on the cap, then put clear coat?
procedure #2: use tapes to cover the cap, then paint the mica blue, put all the sticker, remove the tapes, then put the white color on the cap, then put clear coat?
thanks for the help
Old 01-20-2003, 09:51 AM
flyonthewall's Avatar
Car Mod guy
For such small detail it is best to handpaint them after paint and decals.
Old 01-20-2003, 10:01 AM
joecwlaw's Avatar
so I should paint white on the clear coat, or before the clear coat on blue color, or on the primer?
935k3's Avatar
935k3 935k3 is offline
I usually cut stuff off like that and scratchbuild one later and paint it separetely. Things sticking out like that interfere with polishing of the paint also.
Old 01-20-2003, 10:04 AM
joecwlaw's Avatar
woh, I haven't thought of that. Thanks 935k3, so I should use a sharp cutter to cut it out and then use putty to fix the bottom of the cap and then glue it on after all the clearcoat and polishing?
Old 01-20-2003, 10:16 AM
Vyacheslav's Avatar
Vyacheslav Vyacheslav is offline
Send a message via ICQ to Vyacheslav Send a message via AIM to Vyacheslav
If you are going to glue the cap on the clear coat, isnt cement going to destroy a clear coat just like the paint?
Recently completed models:
JGTC Mobil 1 NSX
Porsche 911 gt2
1985 Toyota Corolla AE86
Old 01-20-2003, 10:18 AM
joecwlaw's Avatar
you seems correct.......guys what I should do?
Old 01-20-2003, 10:31 AM
daggerlee's Avatar
What finish ought the cap be?
Dan
Old 01-20-2003, 10:40 AM
freakray freakray is offline
AF Modelrater
That totally depends on the glue you use.....I use white glue or clear parts glue which is water based and it doesn't harm the paint finish then, when I glue the final parts on.
Ray
AF User Guidelines
Old 01-20-2003, 01:07 PM
Marco_Wrc Marco_Wrc is offline
Rally Fan
Another idea,
sand the original antenna off the roof, drill a hole where it used to be, paint the body, and put on an aftermarket gps antenna. (somewhat in that order)
http://asiapac.worldpay.com/cnb/shop...h=gps&listPos=
or
http://www.hlj.com/cgi-perl/hljpage.cgi?SAK3218
Old 01-20-2003, 06:43 PM
joecwlaw's Avatar
thanks for your info, Marco_Wrc.
I am wondering is there any good website or WRC website having the top view of the WRX WRC1998/1999 version ? (i.e. I saw the links on some thread before, but lazy to find it)
Thanks and appreciated.
Originally posted by Marco_Wrc
Another idea,
or
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
