Old 01-19-2003, 04:06 PM
erbinone's Avatar
erbinone erbinone is offline
What O2 Sensor For My Z6?
Found a guy in the recycler w/ a 4+2+1 Neuspeed header & gonna throw in the O2 sensor for $100. Now, which O2 sensor do I need. Do I need 88-91 ( I have a 90 Sedan & swapping in a D16Z6 ) or the 92-95 sensor? Remember that I'm gonna have the car wirred for the MPFi & VTEC using my Dx harness. Let me know please people. Thanks, Roger
Old 01-19-2003, 04:18 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
You'll need the O2S fro mthe D16z, its a 4 wire sensor....
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 01-19-2003, 06:28 PM
91civicDXdude's Avatar
Use the d16z6 O2 sensor only if you are using the p28 OBD1 ECU, otherwise, it wont wire up correctly. If you're using a non-OBD ECU such as pm6 or pg7, then use an oxygen sensor from a 88-91 Si.
Old 01-19-2003, 07:53 PM
erbinone's Avatar
Which ECU is better to run?? Gonna be my daily driver & what are the advantages to each?
What is the MAF sensor for? And is it that important? IZ1111 General Discussion 14 12-21-2012 10:52 AM
Oxygen sensors.. Can you use any O2 sensor for any vehicle? djshyc Engineering/ Technical 1 03-30-2007 11:26 PM
What is oxygen sensor for? neoavenue Cavalier 10 07-19-2006 12:28 PM
What Type of O2 Sensor for my 96 Grand MA. jeffseby Grand AM 4 09-08-2004 02:03 PM
Torque specs for z6 head? quiXilver '88 - '91 Civic | CRX | Wagon | Shuttlee 1 08-26-2004 08:35 PM
