Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 01-15-2003, 11:04 PM
hondacivic4drlx's Avatar
hondacivic4drlx hondacivic4drlx is offline
Send a message via AIM to hondacivic4drlx
Arrow air suspension
i can already 3 wheel but i wanted to do a suck up. i have an idea of what to do, but dont know if its right. do you put two valves near the exhuast end of the cylinder and then push the piston up and then release it with the 2nd valve. but then wont you have to leave the realese valve open becuase when you try to pick the car up there would be no room for the air to fill the cylinder if the is a limited amount of flow in the exhuast valve line?
any ideas, or suggestion will be fine thank you.
Replace air suspension with standard suspension bobdaman98 Windstar 5 12-10-2009 05:46 PM
Air Ride/Air Suspension?? Wischmaster 3000GT/Stealth 9 04-23-2005 03:04 AM
where is the air pump for the air suspension? kuroc Town Car 1 04-11-2005 03:59 PM
Air Suspension to Regular Suspension movieprops Explorer | Explorer Sport Trac 1 12-24-2004 11:22 AM
