Go Back   Automotive Forums Car Chat > Racing > Street Racing
Old 01-15-2003, 09:56 PM
BeEfCaKe BeEfCaKe is offline
What's the best way to launch?
I'm kinda new to racing... and i just want some tips so i can get some good runs. My main question is what exactly is the best way to launch? I've seen real racing movies(not referring to F&F), and I notice the cars tend to rev really high before(i'm guessing in N or with clutch engaged?), and then shifting to 1st on green?? This does damage the clutch alot correct? And I was thinking, by revving that high, wouldn't you lose alot of traction with wheelspin? So is this really the best way to launch? How do you guys do it?
Old 01-15-2003, 10:30 PM
fatninja19 fatninja19 is offline
Send a message via AIM to fatninja19
First it depends on what type of transmission is in the car.....
and you'd never want to put it in Neutral in a slushbox, rev, then drop it into Drive unless you really hate your transmission and feel that it looks better on the ground, or in separated peices.
I'm a bit lazy to really go in depth, and shall let someone else answer you questions.
when in doubt, throttle.
Old 01-15-2003, 10:56 PM
TatII TatII is offline
well for a manuel all you gotta do is leave it in first then just leave your foot on the clutch then rev to which every rpm is ideal for your car, when its time to go, you just burn your clutch alittle, and leave the throttle on half way, then when your tires finally bite, then you fully let off the clutch, then you just stomp the gas.
303whp stock internal KA-T
94 Acura NSX
Best E.T. 13.559
Best Trap speed 107.62 mph
Old 01-16-2003, 12:57 AM
Self's Avatar
Self Self is offline
Send a message via AIM to Self
Or you could be an allstar like myself and just rev it up to the desired RPM, drop the clutch all the way and feather the gas until the traction kicks in and then go for gold
There's no replacement for displacement...No, not even a turbo.
Old 01-16-2003, 01:42 AM
RazorGTR's Avatar
RazorGTR RazorGTR is offline
Skyline Man
GTR's are pretty easy to launch.
6,800 rpm side step the clutch and you are gone.
You don't own a Skyline, then don't cry to me about it!
1992 Silver R32 GTR tickled to 450hp. - Sold when I left NZ in 2004
Arguing on the Internet is like competing in the special olympics. Even if you win, you're still retarded.
Never confuse kindess with weakness.
AF user guidelines, Please remember to abide by them
Old 01-16-2003, 10:50 PM
Whats side stepping the clutch mean?
Old 01-17-2003, 12:02 AM
Steel's Avatar
Steel Steel is offline
it means to let out the cluth by moving your foot to the side and just letting it pop out as fast as you can. I think.
Old 01-19-2003, 12:35 PM
Pennzoil GT-R's Avatar
Pennzoil GT-R Pennzoil GT-R is offline
yes, GT-R's are very easy to launch, the 4 wheel drive system takes care of the traction
Old 01-20-2003, 10:51 AM
RazorGTR's Avatar
Skyline Man
Yes side stepping the clutch means just that. sliding your foot off the clutch to one side.
On a side note I know why recently my times at the strip were so bad. The 4wd clutch packs in the transfer case are stuffed. Which means not much front wheel torque is being made. Bugger.
Old 01-22-2003, 04:53 PM
$ilverbullet $ilverbullet is offline
Send a message via AIM to $ilverbullet
feather as in slowly tapping the gas? heh, wouldn't your engine stall if you engage the clutch too fast that way?
My 1993 240SX SE Fastback
Old 01-22-2003, 05:38 PM
street_racer_00's Avatar
street_racer_00 street_racer_00 is offline
uhhhhhh I have an automatic Hooray for powerbraking!!!:ylsuper
2000 Nissan Maxima SE, autotragic, sterling mist
My Max: Getting smoked by boosted cars since 2004
2004 AF award winner: longest time period w/o posting an actual street racing story
Originally Posted by CassiesMan
I got to see boobiues!
Old 01-22-2003, 05:41 PM
flylwsi flylwsi is offline
Send a message via AIM to flylwsi
he's referring to what's known in the nhra as "pedaling" the car... once you get the power down and clutch out, you modulate the throttle until you get the traction and then floor it more... if you lose traction, you let off...
Old 01-23-2003, 02:23 AM
TerminalVelocity's Avatar
TerminalVelocity TerminalVelocity is offline
Send a message via AIM to TerminalVelocity
put it into drive and mash out!
*someone had to say it*
My new RHD project!
Solid Crew (Circa 2002)
Old 01-23-2003, 03:32 AM
Self's Avatar
That's what I meant precisely, maybe feathering wasn't the right word...I meant just not put the gas to the floor immediately but rather slightly modulate the amount of gas I'm giving the car so as not to have the tires breaking loose. Thanks for the clarification for me flylwsi
Old 01-23-2003, 12:59 PM
no problem... i do what i can...
the drag racing comparo isn't quite accurate, b/c that's what happens when the car breaks traction down the track, but it's the same idea...
What's the best way to make your factory rims sparkle? JackBauer Yukon 5 05-03-2005 11:09 PM
What's the best way to detail under the hood. starla3366 Blazer 15 09-27-2004 09:07 PM
What's the best way to run battery cables into cab . . .? Bungee C/K 12 08-27-2004 11:31 AM
What's the best way to remove dry spots? dan91SE '88 - '91 Civic | CRX | Wagon | Shuttlee 3 09-23-2003 02:31 PM
what's the best way to clean a dusty engine? AznDragon Integra 6 02-21-2002 10:56 AM
