Old 01-15-2003, 07:36 AM
usarmy1 usarmy1 is offline
Exclamation Engine swap help
I have a 1990 CRX std. I have swapped the d15B2 motor in it with a d16Y7 from a 97 civc. I don't need high performance right now, so I used the intake manifold, distibutor, wiring haness, tranny, and ECU from my old engine. Everything bolted up and engine went in with no problem. I aligned the motor and distributor up to TDC before attempting to crank it. The question I have here is.. Is there anything I need to do special or not to get this motor going? Any info would be greatly appreciated.. Thanks
Old 01-15-2003, 08:39 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
id use the ecu from the y7 instead of ur 90 std, check that first.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 01-15-2003, 09:36 AM
91zc 91zc is offline
The y7 ecu won't work unless he converts to mpfi. He said he is running the intake manifold and fuel injection of the d15 which is dpfi.
91 civic 4dr
b16a
14.8@94
Old 01-15-2003, 12:02 PM
crxlvr's Avatar
oops forgot that part of the puzzle.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 01-15-2003, 12:04 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
did you convert obd0-obd2?
Old 01-15-2003, 12:11 PM
kris's Avatar
kris kris is offline
Off playing with fire.
How, if he is running the dpfi manifold?
Old 01-15-2003, 12:13 PM
mellowboy's Avatar
Re: Re: Engine swap help
Originally posted by kris
I would be carefull about setting vtec to turn on. You dont want to lean out with the dpfi setup.
he has dx motor bro...
Old 01-15-2003, 12:17 PM
kris's Avatar
Re: Re: Re: Engine swap help
I know, I thought I saw y8.
I guess I need to pay attention better.
dakota engine swap jpuckett13 Dakota 0 08-23-2010 08:21 PM
1995 olds achieva engine swap help. handymann3 Achieva 2 01-21-2010 10:26 PM
97 Jimmy engine swap gsnats Problem Diagnosis 5 03-06-2009 10:40 PM
Engine Swap Help, I Am About To Give Up ex2fast4u '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 06-12-2002 09:12 AM
Accord Engine Swap? HELP! OhBabyImRidinLow Engineering/ Technical 2 01-10-2002 10:32 PM
