Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 01-14-2003, 07:31 AM
supafly1024's Avatar
supafly1024 supafly1024 is offline
Help with throttle position sensor.
Can anyone point out the Throttle Position Sensor to me in this picture, or at least give me some idea of where it's at. I'm getting a nitrous kit and I need to hook into the throttle position sensor so that it knows when the car is at WOT (wide open throttle). Thanks for the help.
Old 04-21-2003, 06:29 PM
epax epax is offline
supafly,
just regestered so you probably have your answer,...
anyway the tps is under the yellow hose behind the maniflod,
if you look at the throttle cable from your foot feed it is a cable that wraps around the wheel with the spring behind it, that is the throttle plate shaft on the opposite side of the manifold is where the tps hooks up to the throttle shaft shopuld have a plug with at lease 3 wires in it .
epax
Pontiac GA Cam position sensor LOCATION ? cigars99 Grand AM 6 07-11-2009 10:30 AM
Throttle position sensor replacement help needed fuba Grand Marquis 3 03-21-2006 11:45 PM
Throttle Positioning Sensor...bottom screw!!?? help! Chris8989 Eclipse Problem Diagnosis 1 01-29-2006 11:40 PM
Help with Throttle Position Sensor Code Nayr747 Off-Topic 2 05-28-2005 07:26 PM
throttle position sensor-help JDMrexBoi '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 07-11-2004 02:47 AM
