Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 02-25-2006, 11:47 AM
fuba fuba is offline
Throttle position sensor replacement help needed
I'm trying to get the TPS off but the 2 screws are really frozen. I'm messing up the screws trying to get them to turn.
How do I get these two off? What size are these for replacement? I wish there were bolts, they would be off already.
Old 03-01-2006, 05:59 PM
Marquis_driver89 Marquis_driver89 is offline
Re: Throttle position sensor replacement help needed
I took this of once 2 just to see what it was and all i did was unscrew the screws and it came off fine but for you i would recomend some lube just a bit around the screws if it dosent come off......then im damned
Old 03-21-2006, 11:40 PM
klippersr klippersr is offline
I,m
Old 03-21-2006, 11:45 PM
Originally Posted by klippersr
I,m
I,m not sure if you got your 2 tps screws off, but if your replacing sensor anyway, use a heat gun around screw area, and try loosening screws. If screws are really damaged, you can cut off with dremel grinding tool, and then replace them with allen style head type which I did. Hope this helps.
