Old 09-30-2001, 12:46 PM
Heep's Avatar
Heep Heep is offline
Send a message via AIM to Heep Send a message via MSN to Heep
Painting the body
OK, I know I should have made this my first step, but I put it off and now the entire car is finished except for painting the body and putting it on the car. Now, I just need the low-down on how I should undertake this.
I know to sand first. Got it. Gotta either get a spray can or an air gun tomorrow. Gotta mask off the taillight recesses, headlight recesses, air intakes, bumpers (different color than body), etc. Any tape recomendations? How do I actually paint it? How long to dry? Priming? After painting? Sorry
________________________________________
Mark Brown
1991 Volkswagen Jetta (1.8L I4/5-speed/FWD)
Old 09-30-2001, 03:46 PM
Guiddy's Avatar
Guiddy Guiddy is offline
1. Remove Seam lines
2. Sand whole body with 800 grade
3. Wash and Primer
4. Leave for 24 hours then sand lightly with 1200 grade
5. Spray colour.
6. leave for minimum of 3 days then polish
All details can be added after that, paint in the recesses with silver and the grilles with semi gloss black.
Window rubbers are the hardest to get neat! Best to use a paint pen.
Old 09-30-2001, 03:51 PM
Jay! Jay! is offline
Horizontally Opposed
I use much higher numbers for the sanding grits... I use 1800 on the bare plastic and 2400 between the primer and base coat. And I still always take more paint off than I mean to!
Hierarchy of Subaru:
(Click to see mine!)
Old 09-30-2001, 03:56 PM
Heep's Avatar
Don't push so hard
Thanks for the info guys...
Mark Brown
Old 09-30-2001, 05:13 PM
primera man's Avatar
"P-Man"
When doing a kit i always do the painting of the body first before the rest of the kit. This way the body has a while to "harden" the paint up.
View All My Models Here.
Old 09-30-2001, 05:17 PM
Heep's Avatar
I planned on doing that too, but I had a whole weekend to work until the hobby shops open again, so I couldn't get anything to spray the body with, that's why I hopped right into the rest of the car...
Mark Brown
Old 09-30-2001, 06:35 PM
Chris's Avatar
Chris Chris is offline
Oldie
Send a message via AIM to Chris Send a message via MSN to Chris
Thanks for some of the tips.
Do you find it better to paint the car before or after you are done assembling?? What type of tape do you use?? If you paint the body by itself, do you put it together, or spray the parts separetly?? Sorry, but I want to be perfect:licker:
You can live in a car, but you can't drive a house!!
MSN: [email protected]
Old 09-30-2001, 06:38 PM
Tamiya masking tape, if you can get it.
I do it in parts, but I do them together all at once so they'll all get the same number of coats and end up the same shade. But then you have to deal with gluing the other parts on over the paint job.
Old 09-30-2001, 08:49 PM
Chris's Avatar
Oldie
Would using normal masking tape, put on your clothes first to make it less sticky, work almost as well. Where can I order this Tamiya stuff from??
Old 09-30-2001, 08:57 PM
If your hobby shop doesn't stock it, it's probably too much trouble to order it. Regular masking tape will work. Don't un-sticky it, it should be fine. Just make sure the paint under the tape is completely dry. Like a few days dry. Also, run something flat along the edge to sort of seal it down. Use a pen, a screwdriver, your fingernail, etc...
Remove the tape as soon as the paint is tacky, but before it's all the way dry.
Old 09-30-2001, 08:59 PM
Chris's Avatar
Oldie
Thanks.And I dont have a hobby shop, for that I need to go to Toronto, and I dont know any places there. If someone could help on that, I would be thankful.
Old 09-30-2001, 09:01 PM
So where do you get your kits?
Heep's Avatar
Which is closer to you? Toronto or Barrie? There's a few here in Barrie...
Mark Brown
Old 10-01-2001, 04:29 AM
"P-Man"
DONT USE NORMAL MASKING TAPE PLEASE !!!!!
If you are masking any part on the model that needs a nice fine line,(around windows for the rubbers) only use the Tamiya Tape.
Normal tape can bleed the paint though the edge giving a rough jaggered look to the line.
Old 10-01-2001, 12:28 PM
Guiddy's Avatar
YEP! I second that!
How to Paint The Body??? Naka7a Car Modeling 2 12-31-2005 12:59 AM
ever NOT paint the body..???? pflau Car Modeling 14 12-11-2003 08:20 PM
painting the body yangsta4eva Car Modeling 9 07-09-2003 08:11 PM
When painting the body is it normal to do this??? CRX_SOON Car Modeling 9 01-12-2002 01:29 PM
