Old 12-27-2002, 12:46 PM
Darkwing Darkwing is offline
engine noise
I installed an amp couple days ago and it works great. Sometimes. Depending on how I am accellerating/decelerating the amp will make a buzzing sound, like it is picking up the noise of the CD spinning. Only thing is is that it will do it on radio with the CD out! And it cuts in and out. Also there is a small high pitched whining that is continually going and fluctuates with how hard I press the accelerator. Any thoughts on how to cut this extra garbage out? My amp is a small 50 watt 2-channel if that helps....
and sorry for the other post, its not working.
Old 12-27-2002, 04:58 PM
xivera's Avatar
xivera xivera is offline
Make sure that the power wires aren't running beside speaker/RCA wires.
I/H/E, I.C.E. & other stuff...
Toni/y v0.2|Nice cars thru my lens...
Your first mod = HELMS MANUAL!!!
Old 12-27-2002, 05:14 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
We're still on that ?
Old 12-29-2002, 05:05 PM
the wires BRIEFLY run beside them, but all the wires do, for like, 6 inches maybe? But thats it. Actually, when I installed my driving/fog lights it fixed itself. Then when I was tidying up the wires and all today, I must have touched something I shouldn't have and I blew a fuse. When I replaced the fuse, the new lights worked just fine, but now my amp/speakers/HU is making that damn buzzing again. Please it's driving me crazy how do I stop this? I did it before but I can't figure out what the hell it was that I did! HELP!!!
Check out my webpage at www.darkwing72211.com. It's got a new page specifically for my Car!
Old 12-29-2002, 07:15 PM
les6thboro les6thboro is offline
Send a message via AIM to les6thboro
i solved all my engine noise wheni regrounded my wires.........get a GOOD ground and ur problems are solved
Old 01-01-2003, 12:46 AM
after alot of inspection and thought, I have decided a few things: one is that whatever that buzzing sound is, it's not engine noise. Also, installing my driving lights was not what fixed it before, it was having my regular lights on that made the buzzing stop. (I drove home at night that time)
The noise tends to stop when I do one of three things, 1) make any of the instrument lights come on, 2) come in or out of gear, 3) change from CD player to radio mode on the HU. This is baffling. The only thing that would make sense would be if this new sensor I hooked up to my fusebox was causeing the noise, but when I take it out, it still makes that noise. How aggravating can a problem get? C'mon you guys you are smart tell me what's wrong!
Old 01-01-2003, 07:59 PM
Audio Guy
this sounds like a problem a lot of sound boards have. Try taking the CD ground wire out of the harness and running it straight to a metal part behind the dash.
Old 01-02-2003, 12:47 AM
what does this do? Go ahead and throw all the tech talk at me if you need to. (I'll still try it but wondering why)
2005 Escape LTD - Engine Noise charettk Escape | Maverick | Escape Hybrid 8 11-05-2010 09:24 AM
'81 Deville 368 engine noise 83mb380sl Deville 2 10-17-2010 06:09 PM
1996 Avalon XLS Engine Noise Sarma Avalon/Pronard 0 06-22-2010 09:03 PM
99 Sunfire GT 2.4L Twin Cam Auto--CLICKING NOISES FROM ENGINE BLOCK E. Frank Cavalier Problem Diagnosis 8 07-28-2009 06:25 PM
90 Caprice lower engine noise? jomo3423 Caprice 4 04-18-2009 06:23 PM
