Old 12-27-2002, 08:02 AM
slammed89civic's Avatar
slammed89civic slammed89civic is offline
Send a message via AIM to slammed89civic Send a message via Yahoo to slammed89civic
tach wiring help
ok, i need help wiring up my new tach, i have:
-1 red wire
-1 yellow wire
-1white wire
-1 green wire
-1 black wire
where does everything go?
94 Integra LS, autotragic, Tons of mods
93 Accord wagon, Manual conversion and f20b swap in the near future!
Old 12-27-2002, 08:11 AM
nevermind, i figured it out, it goes like this for any future referance:
-white=12v dash lighting
black=ground (duh)
red=switched power (duh)
green=coil signal
although, i have 1 question.....what wire to i tap the coil signal wire to? (the green one) someone said a while back that there is a place under the dash to tap it to, is this true?
Old 12-27-2002, 11:23 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
I know behind the gauges, there is a blue wire which is your tach wire for the stock tach, don't know if that is what you are looking for or not, but I also think the wire on the dizzy is blue also.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 12-29-2002, 02:15 AM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
on the back side of the cluster there is a connecter on the left side of the back of the cluster.... on the far left side there is a spot for the tach wire...wether it has a tach or not...should be a blue wire...just hook it in there for a tach signal...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Nissan D21 Z24 Z24I Tach Wiring help! jcarr242 Older Pickups 0 11-08-2009 08:11 PM
1979 Tach wire Help ? rh79bird Camaro Discussions 3 04-09-2007 01:51 PM
Tach Wires Help corey71 Camaro Discussions 6 05-12-2004 11:57 PM
tach wiring help Digitalcivic Engineering/ Technical 4 03-04-2002 12:41 AM
tach wiring help Digitalcivic '71-'87 Civic | CRX 1 03-03-2002 09:45 PM
