Old 12-22-2002, 08:30 PM
PorschePong PorschePong is offline
Send a message via ICQ to PorschePong Send a message via AIM to PorschePong Send a message via Yahoo to PorschePong
If the gloss is kinda dull, can I fix it with compound?
Please answer if u can!!
Thnx
Henry
********* H E N R Y **********
Finished:
Old 12-22-2002, 10:15 PM
TheSyndicate's Avatar
TheSyndicate TheSyndicate is offline
Depends if you used gloss paint to begin with. I assume you could be referring to orange peel, in which case you can either sand down with high grit sandpaper, and then polish, or just polish. Finish off with wax.
Old 12-22-2002, 11:32 PM
Thnx for replying.
The problem is, I dun hve any sandpaper thaz over 1000 grids
so I cant do anything with that
I just want to knw if compound would give that glossy and smooth surface back
Thnx again
Finished:
Old 12-23-2002, 12:16 AM
If the paint is smooth, and the paint has hardened for a while, compound should do the trick.
Old 12-23-2002, 03:13 AM
Purpura Delujo Purpura Delujo is offline
Do you kno what do do with metallic paints? I don't get anything wrong with the paint besides that it has no gloss, but I dont wax/polish any of them. Is that why this happens? Could you use wood polish or car polish for a model with Tamiya spray paints?
Old 12-23-2002, 10:50 AM
I hve a mercedes GTR that is painted with Tamiya metallic blue and I didn't compound/wax it.
It turns out fine, but as u said, it is not shiny, but still it looks good because it is smooth
IMO, U might need clear coat for Tamiya metallic paints.
Finished:
Old 12-23-2002, 11:18 AM
What I've discovered is that due to tamiya's metallic paints being lacquer, they have less of a shine. On the other hand, testors enamels require a silver basecoat, and then the topcoat of metallic specs, which has a better outcome.
I'd just clearcoat metallic paints.
what kinda motor can u drop in a talon esi talonesiboy Engine, Transmission and Drivetrain 16 10-18-2006 11:36 PM
2001 GrandAm GT Starting Problems *Not Even the Specialist from GM Canada can fix it! maxivus Grand AM 5 09-11-2005 10:10 AM
My Fuel Sensor is kinda whack...Can someone help me? Ge0Sc0ut Metro 0 03-30-2005 06:38 AM
Another fun fix with the Jimmy JimmySLS Jimmy 3 03-21-2005 01:04 PM
gloss drip... how to fix?? sugarcaddy Car Modeling 2 10-16-2003 05:38 PM
