Old 10-15-2003, 03:23 PM
sugarcaddy's Avatar
sugarcaddy sugarcaddy is offline
Thumbs down gloss drip... how to fix??
I just looked at my new model that I glossed over a week ago, and I found an area where there is a drip that dried right around the door handle. Its a big drip and comes off the body about 2-3 mm. Its big enough to be a big problem on the finish.
Question is: how to fix this problem, striping the paint job is not an option. If I sand the drip down its going to fudge up the paint job because of all the sanding involved. I might be able to trim it off with a new x-acto blade and then compound and sand area, or is there a better way???
Scott
Fastest hunk of junk in the Galaxy.....
Old 10-15-2003, 04:10 PM
Lambo003's Avatar
Lambo003 Lambo003 is offline
Your best bet is to do a careful wet block sanding (fine grit) of the area and try to work it down from there. Follow up with compounding.
Taking a blade to it will only leave divots in your paint.
Chuck
Old 10-16-2003, 05:38 PM
Jumpman_Z's Avatar
Jumpman_Z Jumpman_Z is offline
Send a message via AIM to Jumpman_Z
Re: gloss drip... how to fix??
What he said. You may want to gloss again, too. Don't use the knife. I had a gloss drip on the last model I painted (Q45, not finished yet), and I used the knife to try to fix it. It was better than before, but it still looked a little ugly. Luckily, it was just at the bottom, which hard to notice, and another coat of gloss helped make it look a little better.
Air 23 - News, release dates, info, tons of pics, and much more!!
Air Jordans
Air Jordan release dates
Z33, 287 hp, 274 lb/ft torque. 'Nuff said.
99 escort can/how fix valve seat?? cltrailer Escort 2 11-30-2009 11:56 AM
Drip, Drip, Drip....Follow the Drip! Tinkerin_wit_tools LeSabre 1 10-28-2008 08:06 PM
'95 Auto Trans Slips how fix rdague Escort 6 06-17-2004 09:05 PM
If the gloss is kinda dull, can I fix it with compound? PorschePong Car Modeling 6 12-23-2002 11:18 AM
