Old 12-21-2002, 09:27 PM
fullbloodchop01's Avatar
fullbloodchop01 fullbloodchop01 is offline
Send a message via AIM to fullbloodchop01
Unhappy Epoxy Putty????
i have some of this stuff lying around the house and have tryed i on a scap piece and it looks like im not gonna be able to sand it because, well it looks like is just not meant for sanding, but i have seen tamiya epoxy and have been told to use epoxy so HOW DO I SAND THIS STUFF????:frog:
Rui
(modeling) = Click Here
Old 12-22-2002, 01:12 PM
Ragnarok043's Avatar
Ragnarok043 Ragnarok043 is offline
Send a message via AIM to Ragnarok043
epoxy putty are really meant to be sculpted before it cures since it cures so hard. your suppose to sculp the shape close as possible. if you need to sand start with a much lower grit than you normally would(maybe 180 grit), or you can use a file to take away most of the material.
Old 12-22-2002, 01:39 PM
chaos's Avatar
chaos chaos is offline
AF Premium User
How long do you generally wait before sanding? (after shaping it that is)
Old 12-22-2002, 01:45 PM
depends, some epoxy putty have faster setting times than others. i would say the best type to use would be the smooth type. just smooth it with your hand with some water and theres no need to sand. but im not sure what the setting time on the smooth type.
well i really am not using it for sculpting but more as a large filler. i have to fill in big spaces.:frog:
Rui
Old 12-22-2002, 02:18 PM
Sidewinder-03's Avatar
Sidewinder-03 Sidewinder-03 is offline
Why don't you just fill the space/spaces with styrene sheet or strip and then use squadron putty or Bondo spot glazing putty?
Old 12-22-2002, 04:11 PM
i was thinking of doing that but i had the epoxy putyy laying around here and wanted to see if it would be a good filler.
Rui
Old 12-22-2002, 05:42 PM
hirofkd's Avatar
hirofkd hirofkd is offline
Now, you know it's not.
For a large area, use polyester putty. It start curing in 15 min, and read to sand in 1 hour. It's paste like, and might be messy at the beginning, but using toothpick, you can apply very small amount, and you'll love its curing speed.
Hiroaki Fukuda
Tamiya Epoxy Putty help! turbos86 Car Modeling 20 11-20-2005 05:38 PM
Does epoxy putty have this problem??? integra818 Car Modeling 6 10-11-2002 08:46 AM
Epoxy Putty? integra818 Car Modeling 4 09-18-2002 01:24 AM
How do I dry Tamiya epoxy putty? rupertaker Car Modeling 6 05-30-2002 12:55 PM
How to mix Epoxy Putty (pkw1?) Guiddy Car Modeling 6 12-22-2001 01:26 AM
