Old 12-21-2002, 10:35 AM
plkelley's Avatar
plkelley plkelley is offline
Send a message via AIM to plkelley
It's Working!....It's Working!
Sorry, had to quote a little Star Wars there....anyway
I changed the valve cover gasket today, after I got done I let the car warm up to make sure it wasnt leaking, after it got warmed up I reved a few times to about 3 to 3 and a half grand and the number three piston started working, apparently what ever had it clogged came loose....kick ass!
the only problem now is whem I rev it it smokes quite a bit....I dont know if its because it sat for a long time without running or if some of the seals need changed....what do you guys think. I pretty sure the head gasket is brand new, no external leaks.
Old 12-21-2002, 11:51 AM
jNYCe5 jNYCe5 is offline
Send a message via AIM to jNYCe5
one of the piston rings may be fried, that could be the reason why its smokin..
Old 12-21-2002, 12:25 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
cars do funny things when you work on them. drive it around a couple of days. don't torture run it. see if it's still smoking after a couple of days. is it blue-ish or white smoke? it could be a lot of things from headgasket to seals to rings....
ami
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 12-21-2002, 05:16 PM
plkelley's Avatar
Well i just drove it down the street to change the oil...it was pretty cool, its the first time i've driven it...it wasnt smoking to bad, just a little puff here and there so i think its gonna be alright. it sat for like three years without being started so i think it may have leeked a little oil into various places but as soon as all of it burns up it should be ok, the oil that was in it was about as thin as water so im sure that had a little to do with it to.
2003 T&C front fan not working - it's not the resistor rastoma Caravan | Voyager 4 10-29-2009 08:18 PM
It's PaulD at work PaulD'sRevenge Car Audio 11 06-22-2006 09:27 PM
airbag light on and turn signals won't work... It's not the clockspring!?!? mnewman Caravan | Voyager 12 12-06-2005 06:05 AM
Heater doesn't work... IT'S FREEZING!! 1992eclipseGS Off-Topic 9 02-20-2005 05:55 PM
