Old 02-19-2005, 06:13 PM
1992eclipseGS 1992eclipseGS is offline
Heater doesn't work... IT'S FREEZING!!
Alright... I Garaged (parked in my yard) my 1992 Eclipse GS with hopes of getting a turbo this summer.. Once again my hopes and dreams are shattered.. and i won't be getting a Turbo DSM this summer nor this year.... and i can't keep relying on my G/F for rides.. so.. I have to take out my GS, spends some money on repairs, for some means of transportion this summer... Anywayz.. My heater doesn't work.. It'll blow out warm air for like..say.. 15 seconds after i turn it on.... then it'll turn cold... I haven't checked any fuses yet... I'll start there in the morning.. but.. is there anything else i may need to look into?? I'm Freezing!!... Thanks guys
1998 RS
5 speed, Stock front bumper w/molded urethane lip, Blitz side skirts, Bomex rear, JSP Carbon Fiber hood. Halo Projection Headlights, Escort radar detector, Turbo style spoiler, 1,200 watt sound system with 2 dual 12 subs, 20% executive tint, 17" sport rims, Custom built 2 1/2 Exhaust, OBX 4-1 Header, CAI, KYB GR-2 struts, Sprint lowering springs.
Old 02-19-2005, 06:45 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Heater doesn't work... IT'S FREEZING!!
So the blower motor keeps running but you aren't getting any heat?
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 02-19-2005, 06:49 PM
macder macder is offline
Send a message via MSN to macder
Check your coolant level in your radiator. If theres not enought coolant, the heater has noting to get heat from therefore blows cold air.
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 02-19-2005, 07:17 PM
Re: Re: Heater doesn't work... IT'S FREEZING!!
Yep..
1998 RS
Old 02-19-2005, 07:20 PM
damn.. That might be what it is.. I had a tube break on me awhile ago... so i know there was a little leak.. I'll check up on.. I appreciated fellas...
1998 RS
Old 02-19-2005, 09:38 PM
mitsu_eclipse95gst's Avatar
mitsu_eclipse95gst mitsu_eclipse95gst is offline
Or your heater core is fucked thats worse case
1990 Mitsubishi Eclipse GSX
1995 Mitsubishi Eclipse GS-T (SOLD)
2002 VW Jetta 1.8T
Old 02-19-2005, 10:14 PM
SLoe's Avatar
SLoe SLoe is offline
Your thermostat could also be stuck open.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 02-19-2005, 10:37 PM
With checking your coolant level in the radiator(Properly, opening throttle), you would notice if there is a problem with the thermostat.
-Stage 2 Crane cams
-Custom header
-Bored 0.5mm
Old 02-20-2005, 03:08 PM
kjewer1 kjewer1 is offline
AF - Advisor
Additionally, it wouldnt get warm in the first place to give heat, then cool down. It would always blow cold air. A good suggestion none the less
I'm going to go with coolant level for now.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 02-20-2005, 05:55 PM
SLoe's Avatar
My bad, I guess... I missed ...that part... with all the ... in the way.
