Old 12-16-2002, 11:23 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Distributor got fried
Well, some of you may already know but for those of you who dont, my car died Saturday night. I thought the engine finally bit the dust since its got 201,000 miles on it but i took closer look today. I took off the distributor cap and found that the internal ignition coil thing was just burnt to a crisp. Looked like there was almost a mini explosion in there! The cause was most likely a loose rotor screw cuz it was real loose and wobly when i looked at it today. So, just a heads up to you all, keep an eye on that screw, its definitly a notorius problem in our civics/crx's and can cause some major problems.
Old 12-16-2002, 11:33 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Yeah, I've had mine fall off before... Highly recommend some Loctite on that screw.
Old 12-16-2002, 11:38 PM
onetrueshyguy onetrueshyguy is offline
do you mind posting some pics of it?
and also how do u take the darn thing off?
Old 12-16-2002, 11:50 PM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
Re: Distributor got fried
Exact same thing happened to mine... and the rotor and screw were lose.
just replaced the cap, rotor, and coil and everything worked fine... until the bearings in my distributor went out at least
Honda Enthusiast
Old 12-17-2002, 10:16 PM
sorry, I dont have a digi cam to take any pics of it but trust me, its ugly. But to make sure yours its tight, take off the distributor cap by removing the 4 screws on the outside. When thats offlook at the rotor (the thing sticking out with an arm coming off of it). On the shaft of that rotor there is a screw that i think needs a square screwdriver if i remember correctly, just make sure thats nice and snug and the rotor doesnt have any play. I got a new cap and rotor so now i just have to go to the junkyard this week and get an ignition coil.
Old 12-17-2002, 10:24 PM
Dx18704 Dx18704 is offline
Send a message via AIM to Dx18704
Thanks for the heads up
95 Caprice SW change distributor help (pulley removal) bigwar Caprice 11 02-26-2011 10:19 PM
Fried wires but no fuses blown??? DIYnoob Car Audio 2 09-04-2010 02:14 PM
2002 Distributor Install Procedure wmako M Bodies 2 02-02-2010 09:16 PM
Went to Frys Today & Got These Goodies =) tomazws Car Modeling 3 05-06-2003 04:06 AM
