Old 09-03-2010, 05:02 PM
DIYnoob DIYnoob is offline
Angry Fried wires but no fuses blown???
Hello and thanks for reading.
a couple of days ago i zapped my deck. i self installed my subs and when i was going back to re-wire the amp more cleanly i accidentally let the remote wire touch the ground wire while power was flowing through them and it sparked. the remote wire is tied into my decks power source. I got my friend's deck(both kenwood) and plugged it into the wire harness for my deck and still nothing. The amp and subs are fine still they just have no source now.
the kicker: i looked at the fuses on the amp, deck and in car and cant find one blown. Then i re-did all the wire connections in the back of deck. The only thing left to do i can imagine is go get a tester light which is what i will do now to test the power wire.
granted i am very new to electronics and totally uneducated in the matter i have been doing research the past few days, couldnt fix the problem and finally decided to make an account and post.
Any help will be greatly appreciated
Old 09-03-2010, 05:11 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Fried wires but no fuses blown???
that's strange, I can understand what you did might fry the auto turnon wire to your deck but it should have worked with your friends deck. Take a short wire and jumper the rem lead and + lead on the amp, it should turn on.
NOTE: do not leave the wire on for extended periods when the car is off, it will drain the battery.
Old 09-04-2010, 02:14 PM
ok so it turns out my eyes just suck. I re checked the fuse box under dash and the fuse for radio was blown. not sure how i missed this. replaced the fuse and radio was fine.
i did however fry my rem wire so i decided to install a switch with running new rem wire anyways.
now everything is even better than it was
thanks for that tip it helped me figure out the switch install by the way.
Tags
blown , deck , fried , kenwood , wires
