Old 12-16-2002, 08:31 PM
Cfmotorsports's Avatar
Cfmotorsports Cfmotorsports is offline
Send a message via Yahoo to Cfmotorsports
8 flashes
On my way home this eveing i was running it kinda hard and then the check engine light came on i pulled the panel and it was falshing 8 times and 4 times and it was runnign real rough i reset the computer and it threw just a 8 flashes when you start the car up up after restarting the car it runs fine utill you give it alot of throtle then it comes and the motor runs bad. what could this be and where should i start to look for the problem.
I am running a ZC DOHC in my car
thanks chris
MY MONEY PITs!!!
2001 Silverado-----------90 Civic Si
4.8 V8---------------------ZC DOHC Power
K&N------------------------Intake
2" in the back-------------3.5 Eibach
Rollin on 20's--------------15" AR wheels
Pioneer head--------------Panisonic head
JL 10w6--------------------Infinity Ref
http://community.webshots.com/album/49425207zKoYto
Old 12-16-2002, 08:47 PM
93speed's Avatar
93speed 93speed is offline
Top Dead Center Sensor if its the same as an Accord. I have the same problem. I cannot figure out anything about this stupid sensor. Good luck and let me know what you find out.
Old 12-16-2002, 10:06 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
well the TDCS means that the distributor is not firing at the correct point to meet the cylinders to ignite the burn correctly.
on my crx i had to remove the distributor, set tyhe #1 cyl to TDC then reinstall the dizzy, and check the timing, how it got out of whack so bad when driving is beyond me, but maybe 8 flashes on ur ecu(depends on which one u use) could be a different sensor all together.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 12-17-2002, 05:39 AM
i tried it with pm6 ecu and the pm7 both gave me th same code you think maby the timming just jumped? it is has a tdc on one cam and the dizzy on the the other cam.
MY MONEY PITs!!!
Old 12-17-2002, 04:56 PM
93speed's Avatar
Sorry to hijack the thread, but Do you suggest I do that to my Accord? It started when I had to replace my whole distributor. Could it just be a bad sensor? Where exactly is this sensor located? Oh yeah, it doesnt' happen all the time. Sometimes it'll go away for a while then come back all of the sudden. Like when I'm drivin down the highway the car will jerk and the light will come on. Other times it will come on when the car starts. Its weird.
Damn, I knew I should have asked that question here a long time ago. The 4th gen guys (and gals) always have the answers! :ylsuper
Old 12-17-2002, 07:53 PM
crxlvr's Avatar
the TDC sensor is located inside the dizzy assembly, honda says not to attempt to service the part.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 12-17-2002, 09:15 PM
On my car i have the ZC DOHC i think the TDC is one on the cam outside the dizzy, if so what do i do to check, and does any body have one for sale for a ZC
MY MONEY PITs!!!
Flash ECU, will the car start without? schreib Rodeo | Passport | MU 1 03-15-2010 08:09 PM
94 Metro Code 1 flash then 2 Flash roadcow Metro 7 06-18-2008 10:56 PM
The Flash intro. igor@af AF News 6 04-18-2001 07:28 AM
