Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 12-14-2007, 02:14 PM
todd3po todd3po is offline
Nothing will fix my Heat
Hi everyone.
This is my first post, and my first Toyota truck. I really like the truck, a
91 pu with the 3.0 v6, but the heat does not work. The blower motor works on all speeds and the dampers move to the various settings. The temp gauge in the dash only goes about a 1/4 of the way up. I replaced the thermostat and the waterpump with no change. Water will flow through my heater core, so I don't think that is the problem. I have tried to "burp" it a couple times. I got some air out, but not much and with no change to the heat. I live in Minnesota so any help on how to properly burp it, or any other suggestions would be greatly appreciated.
Thanks
Todd
Old 12-14-2007, 04:25 PM
inafogg inafogg is offline
Re: Nothing will fix my Heat
hey todd do u think your gage is correct??i mean if its only going up 1/4 i would think the water is'nt getting too hot.if thats the case i would suspect the thermostat.what temp.was the one u put in?? are u doing a 50/50 mix on anti-freeze. sorry i cant think of anything that u have'nt already done!!
good luck BTW are both heater hoses at heater core the same temp??
Old 12-14-2007, 04:32 PM
I think it was a 90' stat and I am using 50/50 blend. The gauge in the dash only goes 1/4 up, but the hose coming of the top of the radiator, the radiator itself and the hoses by the firewall going in and out of the heater core are hot. Maybe I need that two stage t-stat I heard about when I searched the forum?
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
always verify a thermostat's fucntionality by putting it a pot of water and bringit to temp bdfore putting it in, saves you alot of grief.
also, always replcae teh radiator cap with the 'stat.
when you fill the radiator up, make it the highest point of the system(uauslly is, but if you have to jack up the front, so be it. start the motor cold with the cap open, and feel the upper hose, you should not feel any water passing through until the stat open then the hose will slowly get hot, when this happens, the radiator should go down, quite a bit, add 50/50 mix top off radiator and proper line on overflow tank.
Old 12-14-2007, 04:43 PM
ok todd if both heater hoses are hot i'd make sure the air is going through heater core!!when switching air temp with dash controls can u hear it change??
Old 12-14-2007, 10:47 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Originally Posted by todd3po
... The gauge in the dash only goes 1/4 up, but the hose coming of the top of the radiator, the radiator itself and the hoses by the firewall going in and out of the heater core are hot. Maybe I need that two stage t-stat I heard about when I searched the forum?
Make sure the valve on the firewall actually moves when you slide the temp control between Hot and Cold. Watch the valve while someone moves the control.
2 stage stat has nothing to do with your problem.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 01-08-2008, 05:20 PM
Thanks everyone for the help, but I kinda hosed myself on this one. So the hot/cold lever not only adjusts the flow of the coolant in the engine compartment, but it also moves some sort of flap or damper under the dash. That cable had fell of its hook and was the reason my heat wasn't working. I now know everything about the cooling system in my truck though. Thanks again to everyone that posted.
Old 01-09-2008, 08:59 PM
fourwd1's Avatar
AF -Advisor
You beat me to it. There must be an epidemic of that going around.
and on a few more on other Toy BBS's.
89 4Runner - stock
