Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 01-06-2008, 03:34 PM
brownbeaver brownbeaver is offline
My heat stopped working and it's winter. help!
well last night the heater in my wife's 96 4runner stopped working instantly.
I manually moved the heater core vavle to open and no difference. I disconnected the hose at the valve and at the other side of the core and blew a garden hose though it. the antifreeze was also coming out of the lines when disconnected. i think i've checked everything and don't know what else. Any help would be greatly appreciated.
Old 01-06-2008, 04:17 PM
Re: My heat stopped working and it's winter. help!
I meant to add that it still blows air just not hot air.
I'm new to this forum but i plan on helping when i can. Any help for me would be great.
Old 01-07-2008, 11:19 AM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
I'm not real familiar w/the 96's HVAC system, but on some vehicles there is a deflector flap in the air ducts which routes the air thru the heater core or the AC core depending on where the temp control is set. They can be cable controlled or vacuum motor controlled, and both methods can fail and stick in one position or the other.
Go to the thread at the top of the main page for links to FSMs and check it out.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 01-07-2008, 02:00 PM
You are exactly right, the cable to the deflector flap broke lose, that awsome thanxs.
thank you again for your help, if it wasn't for you i probly would taken it to a shitty mechanic
