Old 12-07-2002, 08:07 PM
ricktheone ricktheone is offline
Lightbulb spindle
:smoka: Have a problem with taking the rotor off the front drivers brake system was told the rotor was pressed on and you dont need to take off the hub nut I haven't a pulley and I need some advice on how to pull the rotor off please
Old 12-07-2002, 09:22 PM
kris's Avatar
kris kris is offline
Off playing with fire.
There are two screws in between the studs. Undo those. Then there are two bolt holes opposite the screws. Thread a long bolt into those. Then the rotor should slowly pop off.
Old 12-08-2002, 12:28 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
yeah what he said, if your replacing your rotors you can tap the old ones off with a hammer.They do tend to stick sometimes...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 12-08-2002, 03:02 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
The rotor just sits on the wheel studs and is held on sometimes by 2 screws, do like they said to get them off or just bang on it with a rubber hammer and it will come off. The Hub is what is pressed into the knuckle, and the rotor sits on the hub, but they aren't really attached. The only reason you need to take out the spindle nut is to take off the axels or remove the knuckle.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
3 inch drop spindles hitnrun1419 S-10 5 01-19-2003 12:07 PM
Can I use 90-93 Teg spindles on my 90 Hatch STD (4 speed), please help! Maryland90Hatch '88 - '91 Civic | CRX | Wagon | Shuttlee 0 07-28-2002 07:21 PM
can i get cheap dropped spindles for my car? joywrex Classic Cars 1 07-23-2002 09:17 PM
What's the difference between having Drop Spindles in the front and Coils? NassD General Discussion 4 04-21-2002 01:04 AM
