Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-12-2007, 08:39 AM
c.a.r's Avatar
c.a.r c.a.r is offline
Angry Still dont go!!!!!!!!
Hi, I have a '98 Camaro which has also been standing for some time, gone to try and start it with no joy, put a new battery on it and there is no crank, I have some technical knowledge but this sounds like an immobilser problem to me, I have put a feed to the starter to test and it turns over OK and fires for a few seconds then dies, I can here the fuel pump prime up when I turn on the ignition but the light on the dash that says 'SECURITY' stays lit, I have tried to do the bypass by soldering the chip in the wiring at the colomn but still no joy, can anyone tell me where the wires end up so I can check them at the module?, I would be grateful for any help as I am in Spain and there is'nt any dealers nearby. Thanks.
Old 12-12-2007, 08:52 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Still dont go!!!!!!!!
eh, dejavue?
Passlock (security) problem, clean the key and lock cylinder
man, i swear I just typed something like that
welcome to AF.
Old 12-12-2007, 08:58 AM
c.a.r's Avatar
Hmmm! thought if I posted in different area's it might help, also added extra info on this one, working on it as we speak, it is just before 4pm here.
Old 12-12-2007, 11:47 AM
poormillionaire2 poormillionaire2 is offline
Did you get the correct resistance chip when you tried to bypass it. Turned out, the wires from the ignition lock cylinder weren't sending the right signal to the PassKey module, so I bypassed it with a plug-and-play harness from a website. You have to get the correct resistance value though from your key.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
2009 Kawasaki Ninja 500R
Old 12-12-2007, 05:08 PM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Moved to Problem Diagnosis...
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 12-13-2007, 05:36 AM
c.a.r's Avatar
I used the chip from the key for the bypass but added it in to the circuit at the bottom of the steering colomn if I could find out where the module is located I could try it that end, the car is doing my nut in now.
Old 12-13-2007, 09:32 AM
wrightz28's Avatar
If memory serves, Passlock is a BCM function that channels a "all clear" to the PCM.
Old 12-13-2007, 06:42 PM
You have to splice it into the 2 white ignition cylinder wires that connect to the Passkey module. Actually, you have to do it to the wires AFTER the module. But its easy to find, its just a plug receptor, not a module.
This link should help:
http://www.ls1.com/forums/showthread.php?t=61262
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
Old 12-14-2007, 07:57 AM
c.a.r's Avatar
Still no joy, starting to wonder if it is a passlock fault at all, maybe i should start from the beginning!
Old 12-14-2007, 06:31 PM
Check this out:
http://shbox.com/1/pass_key.html
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
