Go Back   Automotive Forums Car Chat > AF in General > Hot and Not > I Want Change
I Want Change This is your forum if you want to start a petition to change AF for the better.
View Poll Results: Do you want this change?
Yes, I want this change 2 50.00%
No, I do not want this change 2 50.00%
Voters: 4. You may not vote on this poll
Old 12-03-2007, 04:53 PM
J-Ri's Avatar
J-Ri J-Ri is offline
IWC: Skill level
I would like to see a ranking system for users skill levels. Occasionally, someone will suggest a fix for a problem that is dangerous or a waste of time. Having some sort of ranking system would allow the user asking advice to know if it is a good solution, or one that will almost certainly end with an explosion. Also, sometimes the user asking a question may omit a very simple test. An experienced technician may assume that everyone would do that test first, and move on to the next step.
I would like a very simple system, perhaps 5 stars under the existing stars?
Different levels could be "I turn the key and go", "I change my own oil", "I can replace random parts", "I'll test it, if I know how", "ASE certified Auto Tech"; or just numbers
DO NOT REPLY TO THIS POST WITH YOUR SUGGESTIONS ON HOW THE PROPOSED CHANGE CAN BE MADE BETTER. START YOUR OWN IWC THREAD IF YOU HAVE AN IDEA ON HOW TO FURTHER IMPROVE AF AFTER THIS CHANGE PASSES OR FAILS.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 12-14-2007, 07:03 PM
00accord44's Avatar
00accord44 00accord44 is offline
High on Potenuse
Send a message via AIM to 00accord44 Send a message via MSN to 00accord44 Send a message via Yahoo to 00accord44
Re: IWC: Skill level
This is not an improvement suggestion or a bash on your idea (which I think is a good concept), it is a question. Who would determine your ranking? And how do you know those people know what they are talking about before they judge others skill level?
ECNATSISER AL AVIV
Old 12-14-2007, 07:10 PM
freakray freakray is offline
AF Modelrater
There is already a system in place whereby moderators select those that have displayed a reliable and thorough knowledge of their chose vehicles - we make them advisors - a step below a mod but somebody we respect for their knowledge.
AF User Guidelines
Old 12-18-2007, 11:01 AM
J-Ri's Avatar
Does the Moderator decide at will to make someone an Advisor, or does one have to request it?
Old 12-18-2007, 11:55 AM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
One of the site's administrators usually makes the final decision. Twospirits generally looks over this forum and decides on matters so it's usually up to him. If and when he renders a decision, you may see the answer next to your thread title. (Just scroll down some of the threads in this forum and you'll see what I mean.)
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 12-19-2007, 08:35 PM
AF Modelrater
It's a decision made by the moderators and admin.
Essentially, one moderator will nominate, then others will second and the admin makes the final call.
If you request to be one, you probably never will be.
AF User Guidelines
Old 12-19-2007, 08:53 PM
Good catch and explanation on that Ray. I misread J-Ri's post and thought he was talking about his original post concerning the use of a "skill level rating system". My explanation to that was that it was up to the site's administrators to decide whether or not to implement an idea brought forth by a member. And their decision is usually posted next to the original thread, ( i.e. Denied, Resolved, Done, etc.)
Old 12-27-2007, 08:29 AM
twospirits twospirits is offline
Ex-Janitor of AF
I concur with what the moderators have said but would like to add the following.
With a forum as large as AF is, we assign moderators on a need to have basis. While the larger sections are constantly being supervised, not every forum/section has a mod. The ones that do, the moderator(s) usually know who are the ones that are suitable for modship. When there are sufficent enough moderators for a section then the member in question would be given the status of an Advisor for either that particular model or section that they give advise on. These Advisors are usually next in line (if the need arrises or a slot is open) to become moderators. For those sections that have less traffic or that a moderator is not supervising, we rely on word of mouth by the other members and or another member informing a mod via PM of a member they would like to nominate for Advisor. The moderator then checks out the members posting history and if the mod decides that the member is indeed knowledgable then the moderator will nominate the member for the status of Advisor (or modship). Once agreed upon, the nomination (whether for Advisor or for Modship) goes to Administration (Igor or myself) and we make it so.
Becoming an Advisor is usually (but not always) a step closer to Modship and becoming an Advisor is not just giving accurate technical advice but also being able to communicate with your fellow members and staff without flamming them, being level headed and above all being an example to others. etc, etc.
Hopefully this answers your question (and its a good one btw). Therefore, I'll make this a sticky so it won't fall down the list for tohers to understand the process.
TS out
The more the members are involved in the process of development, the better we will be as a community of Automobile enthusiasts. Have a suggestion to make the community better, let us know.
Remember, the "No" is always there, you are just looking for the "Yes"
Members please read: Guidelines
