Go Back   Automotive Forums Car Chat > Fabrication & Tools > Machine Tools
Machine Tools Learn about metal lathes, milling machines and CNC tools.
Old 12-03-2007, 11:11 AM
Murray Kish Murray Kish is offline
Getting Old...
Dremels?
So, I keep seeing these ebay auctions for Dremel tool holders to go onto a QCTP.
example:
http://cgi.ebay.com/Dremel-Tool-Hold...QQcmdZViewItem
Ignorance alert: How/why would you put a Dremel tool onto a lathe?
Murray
Old 12-03-2007, 04:47 PM
cinqster's Avatar
cinqster cinqster is offline
Re: Dremels?
Never seen one before. I guess it could be used for cross-drilling (like I'm gong to be doing a lot of with the mill and rotary table) It could be used for grinding keyways/notches etc. but I wouldn't think the tolerances would be too clever?
Old 12-03-2007, 09:46 PM
008's Avatar
008 008 is offline
Re: Dremels?
Grinding attachments for lathes have many uses, one is being able to create extremely sharp points that would be difficult to achieve using a normal tool. A carb needle made out of music wire for an engine, for example.
Old 12-04-2007, 03:22 PM
gionc's Avatar
gionc gionc is offline
Authorized Vendor
Re: Dremels?
Also to do some convex shapes without a special tool. Ex. light proyector.
gio
Old 12-04-2007, 03:31 PM
freakray freakray is offline
AF Modelrater
Re: Dremels?
Polishing and grinding would be a great use.
AF User Guidelines
Old 12-05-2007, 09:31 PM
lam90 lam90 is offline
Re: Dremels?
Another common use is to make a ground finish on an item that you have turned thus giving it a smoother or more percision finish. Typically the item in the chuck is rotated as well as the bit in the grinding tool but in opposite directions.
Best regards,
Larry
example:
Murray
