Old 12-01-2007, 11:07 AM
alsieboy alsieboy is offline
Melandri Spiderman
This one's fustrating me, got the msm Decal set ( 2004 Estoril ), and there's no notes on where the decals go?
Anybody had experince with the model, I just can't work out the helmet decals...
All healp appreciated
Old 12-01-2007, 11:48 AM
freakray freakray is offline
AF Modelrater
Re: Melandri Spiderman
I've found many aftermarket decals require a load of reference photos to be used, more often than not certain manufacturers don't give you any description of decal locations.
If you look at the first post in the other thread you asked in, I think the photo showing the decal sheet and figure in leathers gives a reasonable approximation of where markings go, I think finding more reference material will be crucial though.
Can you post up a photo of the decal sheet you have - I will see if I can tie it together with any photos I can find if it helps.
AF User Guidelines
Old 12-01-2007, 12:06 PM
Here's the decal set I got...
On the right hand side top between the eyes the decal has a curve where the spidey hedgehog sits but is that the top or the bottom of the helmet, plus I can't see the other semi circle pattern to complete arounfd the spidey hedgehog..!!
Old 12-01-2007, 03:08 PM
AF Modelrater
Looking at the image below, I would say that the decal you're referring to is the bottom back of the helmet:
AF User Guidelines
Old 12-01-2007, 03:16 PM
So the ones just below that are the top, but which way round? I just can't get my head around where they go..!
Old 12-03-2007, 07:56 AM
grundski grundski is offline
Send a message via AIM to grundski
Ask Renaissance for a decal instruction set, I think that's who MSM copied thier bike decals from, hence the lack of instructions. They don't know where to tell you to put them. Typical copiers.
Old 12-03-2007, 10:26 AM
hornet1's Avatar
hornet1 hornet1 is offline
I could help you out, because I received a instruction sheet with placement numbers on it from msm. I just doŽnt know how to add a file to this reply, if somebody could tell me?
Old 12-03-2007, 10:41 AM
Have sent you an email direct, if you could mail it to me, then I will add it to this post..Thanx
Old 12-04-2007, 04:28 AM
Got it now direct from MSM
If anybody needs a bigger copy just PM me..
Old 12-04-2007, 05:28 PM
Made a copy of the decal sheet to practice the fit of the web's first, plus didn't know how good they would fit the Rossi Figureine.
I evetually went down the route of cutting off the feet and grafting on a pair of Alpinestars boots from an Airfix Biaggi M1.
The fit doesn't seem too bad although there is a gap on the bottom front of the helmet which will need filling in with extra web's and the shoulders are going to need more webbing to fill in the gaps..
The decals have been put on rough so as to get the outline for painting the red parts...
Old 12-05-2007, 02:16 AM
ketje's Avatar
ketje ketje is offline
Nice start
Old 12-05-2007, 04:50 PM
Just finished painting this figure and started applying the decals....
If I was going to use one word to describe them, it would be....Nasty...
Considering the price they have a very cheap feel to them, and are not individual decals!
Those of you who like me make your own decals will know what I mean, they have been printed and laquered over so when you cut around the decal and soak it you get the clear background as well...very poor and they are really thin and difficult to work with..!!!
very dissapointed at the moment...they look rubbish on the figure, hope they get better once micro sol'd
Old 12-07-2007, 11:33 AM
after much fettling, shrinking and adding many home made webs to fill in the gaps, here's the result.....won't be doing another!
Old 12-07-2007, 03:52 PM
ketje's Avatar
looking good
